Hi:
I am kind of new to using LCD and recently picked up a 633 and 634 for some projects.
I would like to use these with some basic stamps (2C or 2p40) but have some questions.
1. On the sample basic code for driving the serial port of the lcd it suggests jumpering jpe. I see that this is a two position dip switch. Should both dips be in the on position or off. I assume on
2. I see that the lcd header requires a ground (no problem there), two +5vdc sources one for led and one for lcd. Not sure which to use or both.
3. What are SPI_CS, SPi_Clk, SPI_Busy and how are they wired and used.
4. I assume that the serial output of the stamp is connected to the lcd via a db-9 straight thru cable.
Answers to these questions would be most appreciated.
Regards,
Dennis Friedman
Regards,
Dennis Friedman
