I am installing a 633 module and want to try the ATX power supply control capabilities. I have a question with the cabling:
On the page nº 7 of the manual it is said that I should connect the Vsb ("always on" +5v) to the pin 3 of J8. It is also indicated that that pin is electrically connected to the +5V pin of the power connector. Should I wire both pins? I have tested the voltage of the power connector and is arround 0.3V when the system is off.
Does this mean that I should disconnect the +5V cable from the power input? and connect the +5V of the Vsb? What is the exact cabling for this purpose?
Thanks very much.
Thanks very much.
