Hi i have a CFA-635 Display with a SCAB Board connected. I want to use it for a Linux box as ATX controls.
I have connected all cables, have opened JP2 on the CFA-635 as well as JP8 on the SCAB. JP9 on the SCAB is closed.
I have programmed the the GPIO Pins as ATX controls and set the ATX controls with command 28 and saved all as boot state.
The problem is i can reset the box with the CFA and power off as well. But once i have power off the Display is on and shows power off, even the box is off and everything is off. I can't power on as well because it always shows Power off on the display.
The real crazy thing is if i press the power off button on the LCD for 4 seconds again the box powers on?!
I'm stuck and need help
Thanks...
Thanks...
