USB Serial Port Driver not installing ..
phpCypher
the COM port driver install fails with:
"A service installation section in this INF is invalid"
Wintest does NOT work either
phpCypher
CrystalControl Admin said:
Is the LCD listed at all in the ports or USB section of the Windows device manager?
yes this s what it shows:
Forgive the question, but I have to ask:
Do you have administrator priveledges as the user you're installing this as?
phpCypher
CF Support said:
Can you try every USB port on the machine with the device?
I have already tried numerous ports on my machine.
Is it possible that I have a service disabled that is necesary for serial communication ?
I am running a highly modified version of windows that I created with nLite, specifically for it's role as a DAW.
Is it possible, that COM may be disabled from BIOS as well ?
I think that if you created a custom version of XP that it's entirely possible that you left out something to do with plug and play, or the USB subsystem, or something of the like.
I would double check what you've got going there.
phpCypher
okay, got it all working on the laptop, NOW, 635 wintest doesn't do anything, except for "Looking for module..."
any thoughts ?
635_WinTest does not scan the ports (it only polls the one port that is selected), you have to manually select the correct port using the pull-down.
