Jesse Bunch
Urgent Opportunity for 1600 Unused Optrex DMF-510081NB-FW 320x240
I have an opportunity to buy about 1,600 unused Optrex DMF-51008NB-FW 320x240 LCD panels at a closed bid private auction 7/13/2001. If you might have an interest, please contact me ASAP so that we can be more sure to place the winning bid.
These units are unused and in their original boxes.
I can email you the Spec Sheet on request. The Spec Sheet is for the DMF-51008ZNB-FW version. The "Z" in the version now manufactured represents only a change in the glass-level drivers. Thus, these units are completely compatible with the present "Z" version.
Specifications:
Maximum resolution: 320x240 (quarter-VGA)
Backlighting: CCFL(cold cathode fluorescent lamp) x 1
Color: Blue on white or white on blue (inverted)
Overall dimensions: 139.0mm(W) x120.0mm (H - w/o CFL cable) x 13.2mm
Viewing area: 103.0mm(W) x 79.0mm (H)
Dot pitch: .30mm x .30mm
Dot size: .27mm x .27mm
Weight: 250g
Viewing angle: 6:00
Data Transfer: 4-bit parallel data transfer
Operating Temperature: 0°C - 50°C
Storage Temperature: -20°C - 60°C
Compatible Inverters: ERG 1410, TDK CXA-L10L, Elevam S-12561
Date Code: late 1993 (Optrex has assured me that the shelf life is "about forever".)
If you have any questions, please fax, email, or call.
Thanks!
Jesse C. Bunch
Bunch Enterprises
BunchEnterprises@aol.com
301-593-7960
707-929-1734 (fax)
Specifications:
Weight: 250g
Viewing angle: 6:00
Thanks!
Jesse C. Bunch
Bunch Enterprises
301-593-7960
707-929-1734 (fax)
