Unable to configure using CC2
aquilis
I'm able to configure the device using WinTest, so communications are good.
I launched CC2 and selected the device, port, and correct speed. UAC is disabled. This is on Windows Server 2008 R2 with SP1.
I added a screen for testing purposes, and started CC2 service, but nothing updates on the panel. Any help would be appreciated. Thanks.
aquilis
Thanks for your reply.
I have updated to the newer version, and added the latest driver. I tried the 533 driver/module, but the application crashes each time I try to add the module in crystalcontrol2. "CrystalControl2 NT Configuration has stopped working". A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
I replaced the driver with the one windows suggests is compatible with my hardware(the 633), and tried to configure, but it still won't run...here are the logs. Thanks again.
  • CrystalControl2.zip
