Testing out CFAL9664B-F-B1-CB
iox
I just received the CFAL9664B-F-B1-CB which is the LCD with the 2MB-10000 board from 2-bit Micro. I wanted to check to make sure the LCD was working by powering it on manually, is this possible?
I have connected Pin 1 GND to Ground, Pin 8 VDD to +3.3V, and this didn't result in anything. After that, I connected Pin 2, EN_VP to 3.3V also, since I figured that would enable the Vpanel generation voltage, but that still did not result in the LCD backlight coming on, or anything happening.
Is it possible to test the LCD by manually turning it on?
