temp reporting only reports once?
jdgordon
hey,
My computer started overheating so ive finally started writign the fan controller for linux..
anywho... I send the command to report the 2 connected temps and it only reports back once?
so here is my horrible code..
outgoing_response.command = 1;
    outgoing_response.data_length = 0;
    send_packet();
    while (check_for_packet())
        ShowReceivedPacket();
    /* set up temp reporting */
    outgoing_response.command = 19;
    outgoing_response.data_length = 4;
    outgoing_response.data[0] == 0x03;
    outgoing_response.data[1] == 0x00;
    outgoing_response.data[2] == 0x00;
    outgoing_response.data[3] == 0x00;
    send_packet();
    while (1)
        sleep(1);
            char buf[64];
            if (incoming_command.command == 0x82)
                OnReceivedTempReport(&incoming_command,buf);
                printf("%s\n",buf);
now, it should get the hardware info, setup reporting then spit out the report as they come in right?
ok, after a bit of investigating, if i ping the display in the while(1) loop then i will get a fan report (a single 1) and its always "1044.3750?C =1911.8750?F" (string got from the temp->string conversion code in the datasheet)..
am i doing something wrong? or is my hardware faulty or something?
cheers
edit: i just realised i was trying to get a report from my 635 which doesnt have the scab connected... i changed the port to my 631 which does have the scab and still the same.. so im guessing i must be doing something wrong.? (my 631 has a live display setup if that makes a difference)
edit2: im a dill... i was checking for 0x40|19 when i should have been checking for 0x82 which ive changed it to and now i get nothing :'(
________
BONDAGE PAIN
Try this for your loop:
while (1)
    if(check_for_packet(&incoming_response))
        char buf[64];
            printf("%s\n",buf);
jdgordon
hmm...
check_for_packet() is taken from the 631 linux test code and it takes no parameters...
I set it up to show the incoming button packets and that works.. so any other ideas?
________
SQUIRTING BLACK
jdgordon
nope, still nothing.
while (1)
        if (check_for_packet())
            char buf[64];
            switch (incoming_command.command)
                case 0x82: /* temp report */
                    printf("%s\n",buf);
                    break;
                case 0x80: /* key press */
                case 0x81: /* fan */
                default:
button presses work fine, no fan reports (although none are connected) and no temp reports (4 probes are connected).
________
SHOWER TUBES
jdgordon
if(Serial_Init(port,baud))
        printf("Could not open port \"%s\" at \"%d\" baud.\n",port,baud);
        return(1);
    send_packet();
    while (!check_for_packet())
    outgoing_response.data[0] == 0xff;
    outgoing_response.data[1] == 0xff;
    outgoing_response.data[2] == 0xff;
    outgoing_response.data[3] == 0xff;
    send_packet();
    /* and fan reporting */
    outgoing_response.command = 16;
    outgoing_response.data_length = 1;
    outgoing_response.data[0] == 0x0f;
    send_packet();
    while (1)
            char buf[64];
                    printf("%s\n",buf);
                    break;
                default:
     //   usleep(30000);
________
STARCRAFT 2 REPLAY UPLOADER
Have you verified that the same setup will work with 633_Wintest? The code looks ok, but if it works for the fan and key presses, you might have a problem with your OnReceivedTempReport() function. Does it display the temperature reporting packet if this is commented out by defaulting to the ShowReceivedPacket() function?
jdgordon
I commented out all the stuff under the 0x82 case so it falls through to ShowReceivedPacket(); and still nothing.
I have tried the same setup in windows (on another computer though) with 635_wintest and the temp probe reads fine.
________
CHRYSLER 300 LETTER SERIES HISTORY
Pardon the question, but have you power cycled the module since the sensors have been plugged in? It is possible that they haven't been enumerated.
jdgordon
i plugged the 635 into the computer with both the scab and temp prob connected, but other than that, no i havnt. That should be fine tho no?
should i try using the re-enum command before i start?
edit: i thought there was a re-enum command, ill try rebooting i and see what happens
________
Vaporizer
jdgordon
ok, this is wierd...
I do a soft reboot (command 5) and then ping then set up the temp reporting I get this..
C=65( 1 = Read Version),L=16,D="CFA635:h1.0,v1.0",CRC=0x804E447
C=211(Error: Set Temp. Rept.),L=0,D="",CRC=0x8047A14
(i disabled the fan reporting because that seems to work, it was sending lots of "C=129( 1 = Read Version),L=4,D="\003\002\000\000",CRC=0x8044B63" back. ?
edit: just tried this with the 631 and same thing happens :(
________
Threesome Mmw
