New to using your products. After Power up the display seems to not work until a large # of characters is sent to the display. Currently I am using the PING command:
$00,$14,$30,$31,$32,$33,$34,$35,$36,$37,$38,$39,$40,$41,$42,$43,$44,$45,$46,$47,$48,$49,ck <Hex characters, ck is checksum on end of command.
If I send this command 9 times then the display start talking back with the correct response and from that moment on it will continue to work correctly until I re power the unit. If I make the command shorter it takes more of them to get the display talking back so it seems it is tied to the # of characters sent to the display. I know the checksum is correct because sending the command after the display start talking works like it should. Any suggestions as to what to look for?
