Speedfan findings...
Belgarius
Just a couple of things I've found that might save others a bit of grief along the way...
When setting up the voltages, you will need to visit the config of the speedfan app, and take a look at the voltages as they appear in the list. Only those that you select here will show up on the OSD, however, as far as picking up the data, you will need to note where in the list's numbering scheme the actual value you want appears. Once you have determined this, if you are as lazy as I am, all that needs to be done is to edit the right screen file, and transpose the ID numbers.
I've not had any problems with fans, and haven't tried the temps as yet, but don't foresee any issues that won't track back to a liveware problem...:D
Belgarius
