R
robbert229
Guest
I wrote some accelerometer code but will never get around to writing a full and proper document on it. In light of this I am releasing the code that I would build the document around. The code has been confirmed working on a testing 920, but long enough ago that I can't remember if the kernel it was running had any special tweaks allowing this to work. Use the code at your own discretion.
#include <stdlib.h>
#include <stdbool.h>
#include <stdio.h>
I keep the file descriptors in memory to speed up transactions.
FILE *accel_input_x_scale;
FILE *accel_input_x_raw;
FILE *accel_input_y_scale;
FILE *accel_input_y_raw;
FILE *accel_input_z_scale;
FILE *accel_input_z_raw;
Initializes the library. It returns true if the lib was initialized properly, and false if it was unable to.
bool accel_init(void){
accel_input_x_scale = fopen("/sys/bus/i2c/devices/0-0019/iio:device1/in_accel_x_scale","r");
accel_input_x_raw = fopen("/sys/bus/i2c/devices/0-0019/iio:device1/in_accel_x_raw","r");
accel_input_y_scale = fopen("/sys/bus/i2c/devices/0-0019/iio:device1/in_accel_y_scale","r");
accel_input_y_raw = fopen("/sys/bus/i2c/devices/0-0019/iio:device1/in_accel_y_raw","r");
accel_input_z_scale = fopen("/sys/bus/i2c/devices/0-0019/iio:device1/in_accel_z_scale","r");
accel_input_z_raw = fopen("/sys/bus/i2c/devices/0-0019/ii:device1/in_accel_z_raw","r");
return(accel_input_x_scale!=NULL &&
accel_input_x_raw!=NULL &&
accel_input_y_scale!=NULL &&
accel_input_y_raw!=NULL &&
accel_input_z_scale!=NULL &&
accel_input_z_raw!=NULL);
Helper function that reads a accel_input*_scale file and returns its' value in double format.
double accel_get_double(FILE* fin){
char buf[12];
return atof(fgets(buf,11,fin));
Helper function that reads a accel_input*_raw file and returns its' value in integer format.
double accel_get_int(FILE* fin){
char buf[8];
return atoi(fgets(buf,7,fin));
Each of the following functions get the different axis's values in scale or raw.
double accel_get_x_scale(){
return accel_get_double(accel_input_x_scale);
int accel_get_x_raw(){
return accel_get_int(accel_input_x_raw);
double accel_get_y_scale(){
return accel_get_double(accel_input_y_scale);
int accel_get_y_raw(){
return accel_get_int(accel_input_y_raw);
double accel_get_z_scale(){
return accel_get_double(accel_input_z_scale);
int accel_get_z_raw(){
return accel_get_int(accel_input_z_raw);
Closes down the library and frees up the no longer needed resources.
void accel_close(){
if(accel_input_x_scale!=NULL)
free(accel_input_x_scale);
if(accel_input_x_raw!=NULL)
free(accel_input_x_raw);
if(accel_input_y_scale!=NULL)
free(accel_input_y_scale);
if(accel_input_y_raw!=NULL)
free(accel_input_y_raw);
if(accel_input_z_scale!=NULL)
free(accel_input_z_scale);
if(accel_input_z_raw!=NULL)
free(accel_input_z_raw);
Simple main. It gets the data and prints it out.
int main(int argc,char *argv[]){
accel_init();
for(int i=0;i<20;i++){
double x = accel_get_x_scale();
double y = accel_get_y_scale();
double z = accel_get_z_scale();
printf("X:\t%f\nY:\t%f\nZ:\t%f\n",x,y,z);
accel_close();
return -1;
