Serial pinout on 635
Hfuy
I need to make up a cable to go from a motherboard's RS232 DIL header to the back of a CFA-635 with the serial converter board.
When CFA designed that converter board, were they bright enough to make the pinout compatible with the standard motherboard headers, so that I can make up a nice easy 2x5 DIL header pair with IDC connectors and normal ribbon cable, and avoid an ugly re-patch in the middle, to make the pins work out right?
Regards,
H
There are two different ways that motherboard makers lay out their 2x5 serial headers. One way counts down the left side and back up the right, like a DIP package IC. The other way goes right to left and then down like reading a book. We call these "default" and "alternate", and they are listed in the data sheet:
https://www.crystalfontz.com/product/cfa635tfeks-character-module-rs232-20x4-lcd#datasheets
Page 18 lists the default and alternate settings.
There are jumpers on the RS-232 daughter board to support either.
We have an easier method though:
https://www.crystalfontz.com/product/wr232y22
http://www.crystalfontz.com/products/document/1899/WR232Y22.pdf
The single end connects to the display. Then one of the motherboard ends should work, no matter what motherboard you have. And you can do it without soldering :)
In theory: No
A properly implemented RS-232 port should not be damaged by mis-wiring. That is actually a pretty cool feature of RS-232 and probably one of the reasons it has been around for ages.
