Sample code for CFAG12864B-TMI-V
waltrh
We are just starting a design incorporating the CFAG12864B-TMI-V display. I have seen references to sample C-code for this display and would appreciate getting a copy. Our design will use a Rabbit 3400 core module as the micro-controller.
Thanks.
redgren
Hi, anything special I need to do to get blessed with the sample C code? My embedded hardware stuff is just about done, and I would love to get a jump on the coding without having to reinvent work already done.
Thanks in advance.
gaburto
Can I get the Source ?
I am working with the Rabbit 2000 which is very similar to the 3000.
Thanks in Advance
George
bsawatzky
Sample Code For Rabbit 3000 & CFAG12864b-YYH-V
Two questions
1) For every instruction and data that is read / write to the Display are the two columns mutually exlusive.
For example does the Display On/Off command have to be written to both COL 1 and COL 2.
You Block Diagram seems to point to this.
2) Could you please send some sample code for a Rabbit 3000, do you have code that generate alpha /numeric characters.
Thank you for your time,
Brian
