salvaged LCD and controller board pinout
aouate3
I salvaged 2 LCD modules from NEC DTERM Series E phones, they have a controller board on them, i believe it is a samsung board (one board says samsung) the connector is a 16 pin, and the only thing i was able to tell is that pin 2 and pin 5 are ground. the LCD does not have LED backlighting. I need to know the pinout of the board so i can use it in a project
the first lcd board has the numbering
A50-003128- 003
94V0
MBC24302Z03
the second lcd board has the numbering
NG-84458
OPCVO
2421A
SAMSUNG
and on the second board, this is (was) a sticker, some of the sticker is missing, but here is what i can read
UC243902
NARXAA
28
here are pictures of the boards
pictures
here are the last 3 pictures
Ok, this might be ten years too late, but I've just been playing with some LCDs from NEC DTR-16D phones, these have 24 character by 3 line LCDs that look similar to yours, one has the model number NG-87243-001 and a blacked out number NG-84458-001, so presumably it is a revised or modified version. They use a Hitachi compatible controller. I have tentatively worked out that the relevant pins are as follows:
4RS
5E
6D0
7D1
8D2
9D3
10Vcc (3.3V)
11GND
But I haven't actually tried it out from a micro controller, so not 100% confirmed yet.
I have put all the data I know about them on http://projects.scorchingbay.nz/dokuwiki/electronic/lcd/ng87243 (there is data on a few other displays there too at http://projects.scorchingbay.nz/dokuwiki/electronic/lcd/start)
Hope that helps someone.
Back
