First of all i want the thank anyone and congratulate on the new released version. It's good to know there's still support and passion for the great hardware i own.
I Just updated to the latest version (20070720) and latest (unofficial) drivers. I'm running on XP and i skipped the x-mas version btw.
But now i'm dealing with the same problem. CC 2 is not reading te values anymore. But there's more to it. At first startup it actually shows the correct values, but after the first update (after about 10 secs) it gives the [E01]
When looking in the plugin list when selecting "configure" i cannot find the rivatuner plugin/map.
When trying it through another way i came across an error where someone could maybe get a source from where the error is coming from.
The following error comes up:
"a owner plugin for this item could not be found"
this happens when you add a new screen where some of the rivatuner values are already pre-configured. The same event also happens in the window now. So at first startup it give the value as it is supposed to do. After 10 seconds it gives the [E01] When clicking on the [E01] then the error a described above comes up.
Oh the id values i'm using are:
#2701541562(temp)
#3219935972(GPU Clock)
Those values are also shown properly when running plugin-test.exe
Are more people having the same problems?
Or better are there people having solutions
Tnx in advance
BizyB
