jabberwock
I have question about command 5 (Reboot CFA-633, Reset Host, or Power Off Host). I have been applied ATX function on my LCD and set it as default on boot. It works perfectly. But I got some problem about command 5. In my program require to reset LCD itself before initialize all function. I set command show below:
Command = 5
Data_length = 3
Data[0] = 8
Data[1] = 18
Data[2] = 99
This command make host are reset!!!. I need to run program on host and reset CFA-633 by itself for initialize. Is it work? How I set it?
On my host I connected Power on sense direct to ATX. Is there any ATX trigger while I command no.5 out to CFA-633? Is possible to reset by itself while the host program is still online.
Thank you,
Command = 5
Data_length = 3
Data[0] = 8
Data[1] = 18
Data[2] = 99
Thank you,
