It's easy enough to write data to this display thanks to the example code provided, but none of the examples I've seen show how to read data back. I need to be able to determine pixel color for alpha blending, but haven't had any luck reading the GRAM register to get the color. As far as I understand, I need to set the pixel location 'easy enough', make a dummy read, and then read the two 8 bit chunks, but despite trying a number of combinations I'm yet to get any coherent data back.
I've searched high and low on google, but most examples seems to be write-only. Has anyone here figured out the secret formula to get a pixel back? This is my current (hopeless) attempt:
uint16_t lcdGetPixel(uint16_t x, uint16_t y)
ili9325SetCursor(x, y);
return (ili9325Read());
uint16_t ili9325Read(void)
uint8_t argh, argl;
CLR_CS;
SET_CD;
// set GPIO pins to input
ILI9325_GPIO2DATA_SETINPUT;
CLR_RD;
ili9325Delay(50);
// Dummy read
argl = GPIO_GPIO2DATA >> ILI9325_DATA_OFFSET;
SET_RD;
ili9325Delay(50);
// low byte
SET_RD;
ili9325Delay(50);
CLR_RD;
ili9325Delay(50);
// high byte
argh = GPIO_GPIO2DATA >> ILI9325_DATA_OFFSET;
SET_RD;
// Set GPIO pins back to output
ILI9325_GPIO2DATA_SETOUTPUT;
SET_CS;
return argh << 8 | argl;
It would definately be helpful to see this added to the examples since one-way communication definately limits you in how much you can take advantage of the LCDs.
uint8_t argh, argl;
CLR_CS;
SET_CD;
CLR_RD;
ili9325Delay(50);
// Dummy read
SET_RD;
ili9325Delay(50);
// low byte
SET_RD;
ili9325Delay(50);
CLR_RD;
ili9325Delay(50);
// high byte
SET_RD;
SET_CS;
