Program a button on 635
pfostini
I am looking for a way to program one of the 635 buttons to shutdown the computer. Is there any way to do this?
Depends on whether you mean brute-force shut off the power supply, or issue a command to the OS to shut down gracefully.
The brute force method can be done by setting up the "ATX Power Switch" using command 28.
The gracefull method would require a program running in the background that receives the button press reports, and then issues the OS shut down command.
