So I've had some issues getting my Linux terminal servers to send data packets. I've switched these over to Windows. The serial ports are connected to TCP ports as the controlling software is Java and portable serial port control is Java is a joke still. 'nough of that.
This very simple example to clear the screen does not seem to be honored, however the same packet (apparently) via the CFA633 packet debugger (test prog) shows the same thing:
Does something look so terribly off?
OutputStream os; // this comes from either a socket, or javax.comm or file os, etc
// I want to clear the screen:
byte[] ba0 = new byte[4];
ba0[0] = 0x06;
ba0[1] = 0x00;
ba0[2] = 0x5b;
ba0[3] = (byte)0x97;
System.out.println("sending");
System.out.println(new java.math.BigInteger(ba0).toString(2));
// that value as base2 seems to be exactly what I want to send
// 0000 0110 | 0000 0000 | 0101 1011 | 1001 0111
os.write(ba0);
os.flush();
