I am trying to use a PCF8576 to drive an LCD. I can write a 16 byte packet to the driver succesfully via the I2C bus as there is an acknowledgement bit sent by driver after recieving every byte.
The 16 byte packet consists of:
01110000 Slave Address
11100000 Device slelect define device sub-address
01001000 Mode set define LCD drive mode 1/4, LCD bias config 1/3, enable LCD
11111111 Display byte 1
11111111 Display byte 13
The problem is there are no waveform on the backpland or segment output pins.
Any help or torubleshooting advice would be much appreciated.
