When I plug in my new CFA-635 into a USB port I see the following messages in dmesg:
usb 5-2: new full speed USB device using uhci_hcd and address 9
usb 5-2: configuration #1 chosen from 1 choice
ftdi_sio 5-2:1.0: FTDI USB Serial Device converter detected
drivers/usb/serial/ftdi_sio.c: Detected SIO
usb 5-2: FTDI USB Serial Device converter now attached to ttyUSB0
But if I try to use the 635_linux test635 app whose source is downloadable from the the CFA-635 product screen I get the following output:
# ./test635 /dev/ttyUSB0 19200
Ultra-simple CFA-635 command-line communications example.
Usage:
./test635 PORT BAUD
BAUD is 19200 or 115200
Serial_Init:: success
"/dev/ttyUSB0" opened at "19200" baud.
Timed out waiting for a response.
Ctrl-C to exit.
Updated display, now waiting for packets
There's a similar message if I try 115200. I've also tried LCDProc but I get messages like this:
Nov 27 19:40:51 back LCDd: sock_send: socket write error
And when I try LCD4Linux I get messages like this:
Nov 29 23:37:03 back LCD4Linux[31399]: Crystalfontz: timeout waiting for response to cmd 0x22
Nov 29 23:37:04 back LCD4Linux[31399]: Crystalfontz: timeout waiting for response to cmd 0x22
Nov 29 23:37:05 back LCD4Linux[31399]: Crystalfontz: timeout waiting for response to cmd 0x22
Nov 29 23:37:05 back LCD4Linux[31399]: Crystalfontz: timeout waiting for response to cmd 0x06
Nov 29 23:37:05 back LCD4Linux[31399]: Crystalfontz: timeout waiting for response to cmd 0x1f
Nov 29 23:37:06 back LCD4Linux[31399]: Crystalfontz: timeout waiting for response to cmd 0x1f
No matter what I do the CFA-635 stays on the same screen (the factory default screen), same contrast, same brightness, with the text:
Crystalfontz CFA-635
CC 20x4 + keypad &
CC LEDs in 5 1/4" bay
What am I missing?
Donnie
Usage:
./test635 PORT BAUD
Ctrl-C to exit.
CC 20x4 + keypad &
What am I missing?
Donnie
