new time/date display plugin
jdgordon
gday all...
i think ive figured out the plugin stuff which means lots of fun coding for me :) (btw not being able to debug plugins the "normal" way really sux..)
so my first plugin lets u choose exactly how u want to display the date/time..
look here for info on how to display the time (everything there down to tt apart from z and zzz are available) but currently only 24 hour time works...
eg u could display the time on the first row as "hh:nn:ss" or "h:nn.ss" etc.. and the date as "dd mmm yy"...
any letters that arnt on that page will get copied directly into displayed string... (if u want to display a letter which can be converted u need to put a % in front of it)
ok so how do u use this?
dump the attached dll into the service folder with the rest of them then make a screen which has something like this in it
[from00]
from="jdg_time.ini"
sec="time-#"
opt01="id=@01"
opt02="format=dd mmm yyyy"
id and format are the only 2 options available (i will add translation support for the month and day names if ppl want it)
im 90% sure it doesnt crash or freeze the service, but because it is such a pain to test every combination i havnt...
new version...
recompiled wiith the new libs
fixed 12pm being shown as am (as in lunch time, not midnight...)
________
Big tits porn
  • jdg_time.dll
jdgordon
ok, ive updated it to use 12 hour time.. but u have to have one of the 4 am/pm charcters after the time in the format string to work...
to show am or pm add "ampm" to the format sring... "ap" is the same but only the letter a or p.. "AMPM" and "AP" is the same but capitals...
this is what my display screen
[pre]
rows=2
cols=16
[screen]
screen_name="Date/Time"
options=0
alt_delay=5000
[from00]
from="jdg_time.ini"
sec="time-#"
opt01="id=@01"
opt02="format=ddd dd mmm yyyy"
[from01]
from="cc2_time.ini"
sec="time-#"
opt01="id=@02"
opt02="format=hh:nn:ss AMPM"
[r00]
options=5
[r00-i00]
id=@01
[r01]
options=5
[r01-i00]
id=@02
which shows "Sun 27 Feb 2005" "10:01:40 AM"
(grab it from the first post)
________
Bone disorders advice
Perfect!
"Sun 27Feb05" is the format that I prefer and this does it nicely. Your plug-in has found a home on my computer.
You now make me want to go out and get a C compiler (well, almost:) ).
Anyway, congrats on a nice routine to compliment CC2.
You better watch out, tho. You may be inundated with plug-in requests, now.:D
Well done :)
That it does :(
Using the "log_log" function is the easiest way.
If your building a big plugin and do really need to step through it, make it into a simple console app first.
I did with with my game server plugin to make debugging easier, then just copied the code into a plugin when it was ready.
jdgordon,
I am using your time routine with the following format:
format="h:mm AMPM"
It displays the hour and AM/PM correctly. The minutes stays "stuck" at :01. Any ideas as to the problem?
jdgordon said:
<sarcasm> are u waiting longer than 1 min for it to change??? </sarcasm>
Actually, i watched it *patiently* for an hour to watch the hour digit turn over!:D
And if you believe that, I do have a certain bridge to sell...:p
daks001
eg u could display the time on the first row as "hh:mm:ss" or "h:mm.ss" etc.. and the date as "dd mmm yy"...
Are all the output data types strings? If so, is it possible to get output as a number instead? Specifically the h to start off with?
jdgordon
im going to change it to output the first number as a number, so if u want to use bigchars for the clock u will need to setup 1 time for just the hour, and one for just the minutes... no other way im afraid
________
DRUGTEST
daks001
Actually I was just using bigchars because I thought it would only display numerical data and not strings. BUT it turns out that if your h and hh outputs do work in bignums! So I then was trying to plug the hour into another "section" that only accepts numerical data... ;)
It will be quite the event once we can trap time.
jdgordon said:
yep that to :)
actually.. what ill do is add some statis ID's to the plugin to get all the current date/time info without setting anything up manually..
Actually, it would be nice if you and CC admin could roll both your time libraries into 1.
Eventually...
jdgordon said:
mines better than his so his will die.. :p
JOKE... relaaax
Hey, when you're better, admit it!:D
Once you fix the :01 thingy...
FWIW, here is date/time screen. Tell me if anything looks funny...
[pre]
rows=4
cols=20
[screen]
screen_name="Date/Time & Uptime"
options=0
alt_delay=5000
[from00]
from="cc2_time.ini"
sec="time-#"
opt01="id=@01"
opt02="format=ddd ddmmmyy"
[from01]
from="cc2_time.ini"
sec="time-#"
opt01="id=@02"
opt02="format=h:mm AMPM"
[r00]
options=5
[r00-i00]
id=@01
[r01]
options=5
[r01-i00]
id=@02
[r02]
options=5
[r03]
options=5
[r03-i00]
string="Uptime: "
[r03-i01]
id=3451264379
daks001
Move the screen paragraph to underneath the second from paragraph.
[pre]
[from]
[from]
[screen]
[r]
[pre]
[from]
[from]
[screen]
[r]
You are correct, but the cc2_service.ini file corrects it?:
[m01-s01]
options=0
alt_delay=5000
[m01-s01-r00]
options=5
scroll_speed=250
[m01-s01-r00-i00]
id=1410480285
options=0
length=0
[m01-s01-r01]
options=5
scroll_speed=250
[m01-s01-r01-i00]
id=1887909493
options=0
length=0
[m01-s01-r02]
options=5
scroll_speed=250
[m01-s01-r03]
options=5
scroll_speed=250
[m01-s01-r03-i00]
string="Uptime: "
options=0
length=0
[m01-s01-r03-i01]
id=3451264379
options=0
length=0
Anyway, I will rerun with screen add and see if it changes anything.
jdgordon
hahaha i found the problem...
mm is for the month NOT the minutes....
its showing 01 coz ur in feb still (00 is jan)
change it to nn and it will work...
________
MEXICO HOTELS
