New 631 unit - failing to power up
Fred
I received my new 631 usb LCD the other day. Even with multiple attempts I have been unable to get anything out of it. It appears like it is receiving no power. I even removed the usb connectors and directly placed them on the USB pins but still dead as a dodo. Also, my XP system doesn't acknowledge anythings there. Please help
How sure are you of your motherboard connections?
If power and ground are switched - - - this is bad (smoke).
Having D+ and D- switched could cause your problem.
You can always call in and talk to support.
rev_bob
Have you installed the drivers?
I had to install the drivers first and reboot before the unit powered up.
:yL
