Need help using the CFAG12864BTMIV under Linux
Tsuna
Hello to all of you
I've got a brand new CFAG12864BTMIV LCD module [ see @ http://www.crystalfontz.com/products/12864b/index.html#CFAG12864BTMIV ] and I would like to use it on my server, a GNU/Linux Debian box.
I tried out LCDproc, configured it to use the CFontz driver, but when starting LCDd I get the following:
(root@TsunuX)# LCDd
CFontz: init() failed (No such file or directory)
Driver load failed, return code < 0
Could not load driver CFontz
There is no output driver
Critical error: main.c:238, abort
Do I need to compile my kernel with something special or so? I compiled it with the parallel port support I think that's enough.
I reviewed the documentation of LCDproc at http://lcdproc.sourceforge.net/docs/stable-0-4-4-user-html/ but they're not giving any particular information on the CFontz driver.
I also searched this forum but didn't find any useful information about my case.
Any help, hint or advise would be appreciated.
I am not forced to use LCDproc, any other decent application would do.
Best regards,
- Tsuna.
Sorry. I have no idea if LCDproc supports that display. You would have to consult the LCDproc docs or list to see if it is supported.
The only way I know of to connect that display to a PC is by using a parallel cable to the parallel port, which we do not support.
On the windows side, I think Power LCD supports that display (still not supported by us).
