I'm having problems with my CFAG240128LYYHTZ. I've wired many of the mentioned lcds on various pcbs. This last one is causing me headaches. LCD is working ok (I tried it on other board), but when I connect it to my new board, some weird missing pixels occur. I will try to take a pic of the screen, but until then, I'd really appreciate if you guys could give me some pointers on what else to check. I've exhausted my options![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My pcb has:
- Isolated DC 5V voltage. Very stable, not much noise there.
- Good ground
- microcontroller <-> LCD traces are shorter than 1 cm, >= 10 mils.
- I have 100nf and 10 uF (tried 22 uF, no diff) capacitor near lcd power supply (pins 1,2,3)
- I have 100 ohm resistor in series of LCD CE line. Measured with oscilloscope, the CE line is clean.
- I have 100 nF to ground on LCD RESET.
Hope to get some ideas..![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
Marko
My pcb has:
- Good ground
Thanks!
Marko
