kcarbuncle
Info: The LCD is installed correctly (right wiring, etc.) and it works with LCDSmartie (using modified io.sys for 64 bit windows) so i think that the problem stems from the io system file (canio.sys/dll) being incompatible with windows 7...
Am i doing something wrong with the canio.sys file installation or can i use the same trick, replacing the canio files with the io/inpout files that work with win7 64bit?
(really miss CC2's better interface and easier use..)
