LCD software ?
I want to ge the 20X4 Lcd by crystal fontz. I run Windows 2000
what diffrent softwares would you recommend me knowing i run win2k? i would like to know thanx!
Oh yeah i want to do all the cool things that LCD can do such as
MhZ,temp,winamp,time/date,graphs if possible and much other stuff.
leemik
I have the new 634 20x4 serial display and unfortunately LCDriver does not have a setting that works with it... :(
The old 634 20x4 setting just outputs garbage to the 634 2.0...
Do you know of any current driver that does work?
--mike
Please check the baud rate setting switches on the 634 to make sure they match LCDriver.
The v2.0 634 can go to 19.2K baud, and LCDriver is probably set for 9600.
leemik
That worked!!!
As a suggestion, I would ship with it set to 9600 until common drivers start coming out that support 19200 so that you won't have to answer this question a trillion times (like I'm sure you have already) :)
thanks again,
--mike
