I'm using the CFAG128128A, but i can not pass the check status part, i am working with an ATmega16 and my code is the following
I'm pretty sure the code is ok, and when i checked the pins STA0 and STA1 of the LCD, their voltage were around 1.9V, i think this is the problem, it is not a logic "1", anyone know why could be this happening?
int status_check (void)
LCD_DDR = 0x00; //Puerto LCD queda asignado como entrada
LCD_CON_PORT |= (1<<LCD_CD);
LCD_CON_PORT &= ~(1<<LCD_RD);
LCD_CON_PORT &= ~(1<<LCD_CE);
_delay_us(1);
status = LCD_PORT;
PORTA = status;
LCD_CON_PORT |= (1<<LCD_CE);
LCD_CON_PORT |= (1<<LCD_RD);
LCD_DDR = 0xFF; //Puerto LCD queda asignado como salida
return (status);
void data_write (unsigned char data_byte)
do{} while ((0x03 & status_check()) != 0x03);
_delay_ms(1);
LCD_CON_PORT &= ~(1<<LCD_CD);
LCD_CON_PORT &= ~(1<<LCD_WR);
LCD_PORT = data_byte;
_delay_us(1);
LCD_CON_PORT |= (1<<LCD_WR);
return;
