Koolance Flow Meter Screen for CF635
Crystalmancer
[Assuming you have the Koolance Flow Meter and the Koolance Flow Meter Power Adaptor.]
This screen is specific the CF635 with the SCAB module. It uses fan 1 header. If you are using all the fan headers on the SCAB, you could connect the Power Adaptor to a motherboard fan header and read that.
This shows the flow in Liters per Minute and Liters Per Hour.
Water "flows in" through the upper nozzle and "flows out" through the lower nozzle. The turbine "spins".
Author: Crystalmancer
Screen zip file: koolance_flow_meter.zip
Install Instructions:
Copy the gif file to C:\gifs. Or simply use the GIF in your own screen. :)
Included are 20x4 screen files.
You many need to adjust your calc.ini to fine tune it to your pumps tach pulse.
Development thread: N/A.
Hopefully, it works as well for you as it does for me.
Hope you enjoy!
Crystalmancer
