Before examples are discussed here, I would refer you to daks user contributed winamp screens. Open the screen files and note the [event] sections. This is how you program screen specific keypad commands.
You can also program module specific keypad commands, keypad events to control other modules, etc. In my case, I use the 635 left/right keypad to scroll thru my 634 screens.
Life is easier if you program module specific commands (you don't have to know id #'s).
This is also true when programming SCAB screens (see jdgordon's example). In my case, the SCAB that controls my computer fans is attached to my 631. I display SCAB info on my 634 and 635. Consequently, I do not use the [modxx] code.
In otherwords, I have a somewhat complicated keypad structure that I would not want to confuse you with.
Speaking of confused, are you totally confused yet?
Since I use id #'s, I would appreciate it if daks, redeir, or jdgordon upload an example using the [modxx] command.
Once they do, I am sure that more questions and requests will be generated.
Come on guys, let's get these users using the keypad!
