JosephGaudet
So, as part of my project for school I wanted my LCD panel to display bitmaps.
I had tried hacking apart BMP having done it in the past... I ran into some problems and really didn't have the time to sort them out, so I used photoshops raw document.
This little java app accepts a raw document with 240x128 dimensions, it could be easily adapted to the other display formats. It outputs an array that matches the following, fileName[128][30];
It also reverses the bit order such that the bit map can be properly displayed on the CF displays in graphics mode.
Anyway just thought someone might like this.... SO here it is.
syntax for calling is.
java PSRaw "filename.raw"
And here is an example of it's output using a picture of a staples easy button.
Hope someone likes it.
- joe
import java.io.BufferedReader;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileReader;
import java.io.IOException;
public class main {
public static void main(String[] args) throws IOException{
if(args.length != 1){
System.err.println("Incorect number of arguments");
System.err.println("Usage: PSRaw <fileName>");
System.exit(0);
File file = new File(args[0]);
FileReader in = new FileReader(file);
char[] byteBuffer = new char[(int) file.length()];
in.read(byteBuffer);
byte[][] display = new byte[128][30];
int index = 0;
for(int row = 0; row < 128; row++){
for(int col = 0; col < 30; col++){
byte buffer = 0;
for(int bit = 0; bit < 8; bit++){
byte append;
if(byteBuffer[index] == 0)
append = 1;
else
append = 0;
buffer <<= 1;
buffer |= append;
index++;
display[row][col] = buffer;
// Binary Spew
String str = Integer.toBinaryString(display[row][col]&0xff);
while(str.length() != 8)
str = "0" + str;
System.out.print(str);
System.out.print("\n");
// variable spew
System.out.print("extern const byte " + clean(args[0]) + "[][30] = { \r\n");
System.out.print("\t{ ");
String str = Integer.toHexString(reverse(display[row][col])&0xff);
while(str.length() < 2)
str = "0" + str;
System.out.print("0x" + str);
if(col < 29)
System.out.print(", ");
if(row != 127)
System.out.print(" }, \r\n");
else
System.out.print(" } \r\n");
System.out.print("};");
private static int reverse(byte b) {
int result = 0;
result |= (b>>7)&0x01;
result |= (b>>5)&0x02;
result |= (b>>3)&0x04;
result |= (b>>1)&0x08;
result |= (b<<1)&0x10;
result |= (b<<3)&0x20;
result |= (b<<5)&0x40;
result |= (b<<7)&0x80;
return result;
private static String clean(String string) {
String result = string.substring(0,string.indexOf(".raw"));
return result;
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010111111101110111110101000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001011101010101110111010111010110100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001010101011101111011101111101111011010100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001010111111111011010101010101011010110111111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000101111101010101110111111111111110111101101010110000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010110101011101110111010101010101011010110111111111100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001011101110110110101101111111111111101111011110101010111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000101101010101101101111011010101010101011010110101111111101110000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001011011111011011011010110111111111111110111101111010101111011100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000101101101011101101101111011010101010101011010111011111110111110110000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000001010110110110110110110101101111111111111101111101110110111101011011110000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000010111101101101101101101011011010101010101011101011011101110111111110101100000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000101101011011010111011011110110111111111111110111111110111011101010111110110000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000011010110101101111010101101011011010101010101011010101000000001111000000011011000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000010100101101110110101101111011101101101111111010000000011100000000111010000001110110000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000001011111010101101011011010111011011011010100000000000000110000000101000000011101101000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000001010101010111011011101101101010110110110111000000000000000110000000111100000101111011100000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000010101110101010101101110110111111011011011010000001111000100011100000001100000011011100110000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000100010101111101110110101101101000000000011110000000011111011111110000001100000001110111101000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000101101011001010101101011011010000000000001010000000010101111101010000000110100001011101011100000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000010101011101110111011011110110000000000000001110000000000000000111111000000100000011110110101010000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000010010101010101010101101011010000011100000000110000000000000000001011100000000000001111111110110000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000101101110101011101110110101100000010110000000011100000000000000000110110000000000000101010101101000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000001010011001111101011101101111000000111100000000110110100000000000000011111000000000001111111111011000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000101101110100110110011011010000000111000000000011101101111010000000001101000100001001101101010101100000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000001010101011011011000000010111000111100000000000011110111101111000000001111100000000001110111110110100000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000010101011010101100000000001101011011000000000000001011010010101110000001101110000000000111111011001100000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000001010110101110000000000000011110100000011100000001110000000011000000001111011000000001101101110111010000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000010101010110000000000000000110101000000111000000001110000000000000000111011110000100001111011011010110000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000100010101011000001110000000011110000000101100000000111000000000000000011110111100000100111111111101010000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000010101010100000001011000000001010000000110110000000101110000000000001111011011100000000101101010101111000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000101010101100000011110000000011110000000011100000000011101010101010111101111110000000001111111111101010000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000100101110100000010100000001101100000000010000000000011011111010111110111010100000000000110110110110110100000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000110010011000000000000000101110110000000000000000001011110101111101011101111100000000011011111111011011000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000010001101110100000000000011110001011000000000001010111111011110110111110111010110000000001111010101100101010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000110011001000000000001111000000110000000000001111110110111011101101011101111100010010111110111111011111000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000001001101111000000000111100000001101100000000111101101101101110111011110111010111101101101011101011101010010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000100100010101100000000110110000000111110001011110110110110110111011110111011111101111111111101111101101101001000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000001010101110100000000010101000000101011110111011011011011011101101011101101010111010101010111010110110111010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000100101010101100000000011110000001111111011110110110110110111011011111011111111110111111111110111101101010000100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000001000100101111010000000001000000011010101110101101101101101101110110101110101010101101010101011101111011110101000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000110110101110000000000000000011111110101110110110110110110111011110111111111110111111111101110101101010000100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000001010001001010101000000000000001110101011111011011011011011011101111011101010101011110101010111011110110110101000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000010000110011111111000000000000011101111101010110110110110110111011010111011111111110101111111110110101101100010010000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000100001101010101100000000011110111010111111101101101101101101110111101110101010111111010101011101110111010100100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000010000100101101110110100011101011011111010101110110110110111110111101110111111111010101111111101110101011000010010000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000010011010111011011011110111101110101111111011011011011101011010111011101010101111111101010111011111101110100100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000010100000101010110110110101101011101111101010110110110111011111111110110111111111010101011111110111010011001001001000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000001001010111011011101111011110111010111111101101101101110101010101111101010101111111110101011101101110000010010000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000101000000101001101101010101101011011111010101110110110110111111111111010111111111010101011111101110110101010100100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000010100010111011011111110111101110101111111011011011011010101010101111101010101111111111010110101101010100010001000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000100000101000110111010101101011101111101010110110111110111111111111010111111111010101010111101111011100010100010000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000101001010010011011010111111011110111010111111101101101011101010101011111101010101111111111101011010101001001001000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000001001101111010101101011011111010101110110111101111111111101010111111111010101010111101101110000100100101000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000010101001010010101111110111101110101111111011011010111010101010111111101010101111111111010111010101010010010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000010100000000101011011010101101011101110101010110110111110111111111101010111111111010101010111010101100100100100101000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000001010100000010110111111011110111011111111101101101011101010101111111101010110111111111101101011001001001001000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000100000000011001011010101101011011101010101110111111101111111110101010111111011101010101110110100000100100000010000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000100000010101000100101101110111101110111111111011101010111010101011111111110101110111111110101101111010010010101000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000010100000000001001011101101011101110101010111011111110111111111010110101111011101010101011001000100100100000001000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000001010100010010110111011110111011111111101110101011101010101111101111011110111111111100110000001001001010100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000010001000000010001000011010101011011101010101110111111101111111111010111011101011101010100111010010100100100000010000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000100101001000101000111111101110111111111011101010110101010101111101110111110111111011001000100010010001010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000010000001000000000000001010101011101010101010111011111111111111111110111101110101101010110110001010100100100000010000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000010101010001010001110110111111111111101110101010110110101011101011011111011101001000100000010001000001000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000001000100000000001000001000011011010101010101110111111111011011111110111111101011110101100010010101001000010000100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000010010100010000101000101111111111111011101010101111111011011011010111110101010010101001000100101000001000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000100001000100001000100000101010101010101010110111111111110101110111110111101101101010001000010101000000000010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000001000000000001000010001000000101011111111111111101101101011111011101011111111010010000110010100000010100000100100000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000010000010000101000100010010000100010110110101110110111110111110111111101010101001010001001010101000000000010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000100000010000001000010010101011011111111111110111101111111110110101010010101100100000000001000001000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000101000000001001000010100010100001001010101011011111111111111101101001101010100101010001010101010100000000010000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000010100000000001010010001010101101010101010101010101110010101011010101010000010000000000010100000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000010100000000100000001010101000001001100101010101010110101010110100001010101001011010101010100100000000001000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000010000000010100100000000010100100011010101010101001010101001011111101010110110101000100010010000001010000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000100000000000000000101001000000000100101010101010110101010111101010010101101100110101010100000000000100000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000001000000000101010000010010101010001000101011101101111111010110101101111010011010100101000000000010010000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000100100000000000000101000000000001000101001000100101000101101011010110101011100101010000000000000001000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000001001000000001010000010101010100010010010101011010111010010101111011011010011111101101000000010100100000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000010000000000000010100000000000100100100101010010100111111111101101010101101010010000000000000001000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000100101000000101000001010101010001001001010101101011101010101010110111011011010100000000000101010000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000010000000000000101100100000001000100100001010010101111111010111011010101101010000000000010000100000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000101010000000010001001011010010001001100100101010101001111010101111110110101000000001001010000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000001000000100000001011011010010110110011001001010101110111010111111010101100000000000000000100000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000010101000000000000100101101001001100110111101111011101111101010111010001000000000101010000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000001000010100001010010101010110110111011010110101101110101011111001010100000000010000101000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000101000010100001010101011011011101101111011110111011111101010110100000000001001010000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000010010100001000001010110110101011011010110101110101010110101001000000001010010100100000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000100001010010100101001011111110110111101111011111101011010100000000100100100010000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000010100001001010001010100101011011101111011101010111001010010001010100010010100000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000010100100000110101011010101110110101101011101100101001001010101001001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000100000000101000101010101110101101111010110011011010010010101000010010010000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000001010101000010010101010101101011010111011100100101101101000010100100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000101001000010101010111101101010101011011010100000101001010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000100101000000101000011011101110110101010001010010010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001010000000010101000010100100010001000100001010100100100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001010101000000010100001001001010010010100000010010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000101010000010100100100001001001010110101000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010000000101000010010010100100100001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010101000010100100101001001001010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000010100001001000010010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
extern const byte easy_down[][30] = {
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0xbf, 0xfb, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5d, 0x75, 0xd7, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0xea, 0xde, 0x7d, 0x6f, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd4, 0x7f, 0xab, 0xaa, 0xb5, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7d, 0xd5, 0xfd, 0xff, 0xde, 0x6a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0xab, 0xbb, 0xab, 0xaa, 0xb5, 0xff, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd0, 0xdd, 0xd6, 0xfe, 0x7f, 0xef, 0x55, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb4, 0x6a, 0x7b, 0xab, 0xaa, 0xb5, 0xfe, 0x1d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xda, 0xb7, 0xad, 0xfd, 0xff, 0xde, 0xab, 0x77, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xb6, 0x6e, 0x7b, 0xab, 0xaa, 0x75, 0x7f, 0xdf, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x6d, 0xdb, 0xd6, 0xfe, 0x7f, 0xdf, 0xed, 0xb5, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0xb7, 0x6d, 0x6b, 0xab, 0xaa, 0x6b, 0x77, 0xff, 0x1a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd0, 0xda, 0xba, 0xbd, 0xfd, 0xff, 0xfe, 0xdd, 0xd5, 0x37, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xac, 0xb5, 0x57, 0x6b, 0xab, 0xaa, 0x55, 0x80, 0x07, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xd2, 0x6e, 0xed, 0xdd, 0xf6, 0x17, 0xe0, 0x00, 0x17, 0xb8, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7d, 0xb5, 0xb6, 0x6e, 0x5b, 0x01, 0x80, 0x01, 0x05, 0xdc, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0xaa, 0xdb, 0x6d, 0xb5, 0xed, 0x00, 0x80, 0x01, 0x0f, 0x7a, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x57, 0xb5, 0xdb, 0x6f, 0x5b, 0xe0, 0x11, 0x07, 0x0c, 0xec, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x88, 0xfa, 0x6e, 0x6d, 0x01, 0x78, 0x80, 0xef, 0x0f, 0x0c, 0xb8, 0x17, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x68, 0x4d, 0xb5, 0xb6, 0x00, 0x50, 0x80, 0xfa, 0x0a, 0x58, 0xe8, 0x3a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xaa, 0xbb, 0xdb, 0x1b, 0x00, 0x70, 0x00, 0x80, 0x1f, 0x08, 0xbc, 0x55, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x52, 0x55, 0xb5, 0x16, 0x1c, 0x60, 0x00, 0x00, 0x3a, 0x00, 0xf8, 0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xed, 0xea, 0x6e, 0x0d, 0x34, 0xc0, 0x01, 0x00, 0x6c, 0x00, 0x50, 0xb5, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x32, 0x5f, 0xb7, 0x07, 0x1e, 0x60, 0x0b, 0x00, 0xf8, 0x00, 0xf8, 0xdf, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xed, 0xb2, 0xd9, 0x02, 0x0e, 0xc0, 0xed, 0x05, 0xb0, 0x08, 0xd9, 0xaa, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xaa, 0x6d, 0x40, 0xc7, 0x03, 0xc0, 0x7b, 0x0f, 0xf0, 0x01, 0xb8, 0x6f, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0xb5, 0x1a, 0x80, 0xb5, 0x01, 0x80, 0x96, 0x3a, 0xb0, 0x03, 0xf0, 0x9b, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x5a, 0x07, 0x00, 0x5e, 0xe0, 0x80, 0x03, 0x0c, 0xf0, 0x06, 0xd8, 0xee, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0xd5, 0x00, 0x00, 0x2b, 0x70, 0x80, 0x03, 0x00, 0xdc, 0x43, 0x78, 0x5b, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0xaa, 0xc1, 0x01, 0x1e, 0xd0, 0x00, 0x07, 0x00, 0x78, 0x0f, 0xf2, 0xbf, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x55, 0x40, 0x03, 0x14, 0xb0, 0x01, 0x1d, 0x00, 0xde, 0x0e, 0xd0, 0xaa, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0x6a, 0xe0, 0x01, 0x1e, 0xe0, 0x00, 0xae, 0xaa, 0xf7, 0x03, 0xf8, 0xbf, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x5d, 0xa0, 0x80, 0x0d, 0x20, 0x00, 0xf6, 0xf5, 0x5d, 0x01, 0xb0, 0x6d, 0x0b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x32, 0x00, 0xa0, 0x1b, 0x00, 0x80, 0x5e, 0x5f, 0xf7, 0x01, 0xec, 0xdf, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x88, 0x5d, 0x00, 0x78, 0x34, 0x00, 0xea, 0xf7, 0xf6, 0x5d, 0x03, 0x78, 0x35, 0x15, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x26, 0x00, 0x1e, 0x18, 0x00, 0x7e, 0xbb, 0x5b, 0xf7, 0x91, 0xbe, 0xdf, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90, 0x3d, 0x80, 0x07, 0x6c, 0x80, 0xb7, 0xed, 0xee, 0x5d, 0x6f, 0xeb, 0xba, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24, 0x6a, 0x80, 0x0d, 0xf8, 0xe8, 0x6d, 0xdb, 0xbd, 0xfb, 0xfd, 0xdf, 0xb7, 0x25, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x5d, 0x00, 0x15, 0xa8, 0x77, 0xdb, 0x76, 0xeb, 0x56, 0x57, 0x75, 0x6d, 0x17, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa4, 0x6a, 0x00, 0x0f, 0xfc, 0xbd, 0x6d, 0xbb, 0x7d, 0xff, 0xfb, 0xbf, 0xb7, 0x42, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x22, 0xbd, 0x00, 0x02, 0x56, 0xd7, 0xb6, 0xed, 0xd6, 0x55, 0xad, 0xea, 0xde, 0x2b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0xeb, 0x00, 0x00, 0xfe, 0xba, 0x6d, 0xdb, 0xbd, 0xff, 0xfb, 0xdf, 0xb5, 0x42, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8a, 0x54, 0x01, 0x80, 0xab, 0x6f, 0xdb, 0x76, 0xef, 0xaa, 0x5e, 0x75, 0x6f, 0x2b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x61, 0xfe, 0x01, 0xc0, 0x7d, 0xb5, 0x6d, 0xbb, 0x75, 0xff, 0xeb, 0xbf, 0xb5, 0x91, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x84, 0x55, 0x03, 0x78, 0xd7, 0xdf, 0xb6, 0xed, 0xde, 0x55, 0xbf, 0xea, 0xee, 0x4a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x21, 0xed, 0x16, 0xd7, 0xbe, 0xba, 0x6d, 0xdf, 0xbb, 0xff, 0xea, 0xdf, 0xd5, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc8, 0xba, 0xed, 0xbd, 0xeb, 0x6f, 0xdb, 0xb5, 0xee, 0xaa, 0x7f, 0x75, 0xbf, 0x4b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0xd5, 0xb6, 0xd6, 0x7d, 0xb5, 0xed, 0xfe, 0xb7, 0xff, 0xaa, 0xbf, 0xcb, 0x24, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x90, 0xba, 0xdd, 0x7b, 0xd7, 0xdf, 0xb6, 0xab, 0xfa, 0xaa, 0xff, 0xea, 0x76, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x02, 0x65, 0xab, 0xd6, 0xbe, 0xba, 0x6d, 0xff, 0xaf, 0xff, 0xaa, 0xdf, 0xad, 0x4a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x28, 0xba, 0xfd, 0xbd, 0xeb, 0x6f, 0xdb, 0xaa, 0xfa, 0xaa, 0xff, 0xb5, 0x56, 0x11, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0xc5, 0xae, 0xd6, 0x7d, 0xb5, 0x7d, 0xff, 0xaf, 0xff, 0xaa, 0xde, 0x3b, 0x8a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x52, 0xb2, 0xf5, 0x7b, 0xd7, 0xdf, 0xd6, 0x55, 0xfd, 0xaa, 0xff, 0x6b, 0x95, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x64, 0xaf, 0xd6, 0xbe, 0xba, 0xbd, 0xff, 0xab, 0xff, 0xaa, 0xde, 0x0e, 0x49, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa8, 0x94, 0xfa, 0xbd, 0xeb, 0x6f, 0xeb, 0xaa, 0xfe, 0xaa, 0xff, 0x75, 0x55, 0x12, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0xa8, 0xad, 0xd6, 0x5d, 0xb5, 0x7d, 0xff, 0xab, 0xff, 0xaa, 0xae, 0x26, 0x49, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x81, 0xf6, 0x7b, 0xf7, 0xdf, 0xd6, 0x55, 0xff, 0x6a, 0xff, 0x5b, 0x93, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x30, 0xad, 0xd6, 0xae, 0xba, 0xbf, 0xff, 0xaa, 0xdf, 0x55, 0xb7, 0x20, 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x40, 0x45, 0xda, 0xbd, 0xfb, 0xef, 0xea, 0xaa, 0xff, 0x75, 0xff, 0xda, 0x4b, 0x2a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x28, 0x00, 0xe9, 0xd6, 0x5d, 0x75, 0x7f, 0xff, 0xb5, 0xde, 0x55, 0x4d, 0x24, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x8a, 0xb4, 0x7b, 0xf7, 0xdf, 0xd5, 0x55, 0xdf, 0x7b, 0xff, 0x33, 0x90, 0x54, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x11, 0x10, 0x61, 0xd5, 0xae, 0xba, 0xbf, 0xff, 0x75, 0xd7, 0x55, 0x2e, 0x25, 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x25, 0x8a, 0xbf, 0xfb, 0xef, 0x6a, 0x55, 0xdf, 0x7d, 0xbf, 0x89, 0x48, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x81, 0x00, 0x40, 0xd5, 0x55, 0x75, 0xff, 0xff, 0xf7, 0xae, 0xd5, 0x46, 0x25, 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xaa, 0x28, 0x6e, 0xff, 0xdf, 0x55, 0x5b, 0x5d, 0xfb, 0x2e, 0x11, 0x88, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x22, 0x00, 0x41, 0xd8, 0xaa, 0xba, 0xff, 0xf6, 0xf7, 0xd7, 0x6b, 0xa4, 0x12, 0x42, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x52, 0x84, 0xa2, 0xff, 0xef, 0xaa, 0xbf, 0x6d, 0x7d, 0x95, 0x4a, 0xa4, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x84, 0x08, 0x11, 0x54, 0x55, 0xb5, 0xff, 0xeb, 0xbe, 0xb7, 0x15, 0xa1, 0x02, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x20, 0x44, 0xa0, 0xfe, 0xff, 0xb6, 0xbe, 0xeb, 0x5f, 0xc2, 0x14, 0x28, 0x48, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x42, 0x11, 0x09, 0xd1, 0xd6, 0xed, 0xfb, 0xfe, 0xaa, 0x14, 0xa9, 0x02, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x04, 0x42, 0xaa, 0xfd, 0x7f, 0xef, 0xbf, 0x55, 0x6a, 0x02, 0x10, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x20, 0xa1, 0x28, 0xa4, 0x6a, 0xff, 0x7f, 0xcb, 0x2a, 0x15, 0x55, 0x05, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x80, 0x12, 0xd5, 0xaa, 0xaa, 0x3a, 0xd5, 0xaa, 0x20, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x28, 0x40, 0x40, 0x15, 0x64, 0xaa, 0x6a, 0xd5, 0x42, 0x95, 0x56, 0x95, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x80, 0x12, 0x40, 0x89, 0x55, 0x95, 0x2a, 0xfd, 0x6a, 0x2b, 0x22, 0x81, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x80, 0x12, 0x40, 0xaa, 0x6a, 0xd5, 0x2b, 0xb5, 0x59, 0x15, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x2a, 0x48, 0x15, 0x51, 0xb7, 0xbf, 0xd6, 0x5e, 0x56, 0x0a, 0x40, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x01, 0x80, 0x02, 0x20, 0x4a, 0xa4, 0x68, 0xad, 0xd5, 0xa9, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x04, 0x28, 0xa8, 0x8a, 0xa4, 0x5a, 0x97, 0x7a, 0x5b, 0x7e, 0x0b, 0x28, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x05, 0x40, 0x92, 0x4a, 0xf9, 0xdf, 0xaa, 0x95, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x29, 0x50, 0x50, 0x15, 0x49, 0xb5, 0xae, 0xaa, 0xdd, 0x56, 0x00, 0x54, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x80, 0x26, 0x20, 0x12, 0x4a, 0xfd, 0x75, 0xab, 0x15, 0x00, 0x21, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa8, 0x00, 0x91, 0x96, 0xc8, 0xa4, 0x2a, 0xaf, 0x7e, 0x2b, 0x40, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x02, 0xda, 0xd2, 0x66, 0x52, 0xdd, 0xf5, 0xab, 0x01, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x01, 0x20, 0x2d, 0x99, 0xbd, 0x77, 0x5f, 0x5d, 0x04, 0x50, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x14, 0x4a, 0xd5, 0x76, 0x6b, 0xed, 0xea, 0x53, 0x01, 0x84, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0xa1, 0x50, 0xb5, 0xdd, 0xde, 0xbb, 0x5f, 0x2d, 0x00, 0x29, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x14, 0x82, 0xda, 0x6a, 0x6b, 0x5d, 0xb5, 0x12, 0xa0, 0x94, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x29, 0xa5, 0xbf, 0xbd, 0xf7, 0x6b, 0x05, 0x48, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x52, 0x54, 0x6a, 0xf7, 0xae, 0x4e, 0x89, 0x8a, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0x04, 0xab, 0xd5, 0xad, 0x75, 0x53, 0x52, 0x25, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0xa0, 0xa8, 0xba, 0xf6, 0x9a, 0x2d, 0xa9, 0x90, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x15, 0x52, 0xd5, 0x5a, 0x77, 0xd2, 0x16, 0x4a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa2, 0x84, 0xaa, 0xb7, 0xaa, 0xad, 0xa0, 0x14, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x29, 0x50, 0xd8, 0xdd, 0x2a, 0x4a, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x50, 0x80, 0x0a, 0x25, 0x22, 0x42, 0x25, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x2a, 0xa0, 0x90, 0x94, 0x14, 0x48, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x05, 0x25, 0x21, 0xa9, 0x15, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x50, 0x48, 0x4a, 0x42, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x0a, 0x25, 0x25, 0x29, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa0, 0x90, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
- joe
