jaLCD+LCDriver+winxp not working :confused:
jayklm
I am trying to get jaLCD to work. I have a CF 634 serial. I installed LCDriver (test works fine from the control panel). I am running WinXP pro. I installed jaLCD 3.01.
? I tried loading 420.cfg. I changed the port to”lcdriver”.
Any ideas :confused:
jayklm
Americanfreak
download ver 3.10.........put in what com port yout LCD is, like com2 save it as your config file......you should be good to go to start to making your own screens........I don't think you need LCDriver to run jaLCDs.....I use both jaLCDs and CC
jayklm
Now I feel blind. I noticed that you have 3.1 and not 3.01! I looked all over jalcd's site and I am unable to locate the newer version. do you have a link? or point me in the right direction.
thanks again :)
jayklm
Edit: Found it in the forums :)
