Initalize cfag240128
BrAjN
Initalize cfag280128
Hello, i have a cfag280128 display based on sanyo lc7981, and have problem to init this display.
I use C language for interfacing my PIC micro on Display, i need an example or a true table for inizialize this controller with the state of pins E, RS, and DB.
I have a table example on datasheet but the display doesn' t work for errors with the "code init".
Thanks!
BrAjN
I have read the code example and tryed the test program the dispplay work correctly, but my code doesn't work :(
The init sequence is wrong????
PHP:
#include <pic1687x.h>
#include "delay.c"
#define LCD_RS		RA2	//Register Select
#define LCD_EN		RA3	//Enable
#define LCD_CS		RA5	//Chip Enable (Attivo a 0)
#define LCD_D0		RB0	//LCD Data 0
#define LCD_D1		RB1	//LCD Data 1
#define LCD_D2		RB2	//LCD Data 2
#define LCD_D3		RB3	//LCD Data 3
#define LCD_D4		RB4	//LCD Data 4
#define LCD_D5		RB5	//LCD Data 5
#define LCD_D6		RB6	//LCD Data 6
#define LCD_D7		RB7	//LCD Data 7
int x;
int row, col;
void LCD_STROBE();
void ins_reg (int byte)
	PORTB = byte;
	LCD_RS = 1; //Write Instruction
	LCD_CS = 0; //Chip Enable
	LCD_STROBE();
	LCD_CS= 1; //Chip Disable
void data_reg (int byte)
	PORTB = byte;
	LCD_RS = 0; //Write Data
	LCD_STROBE();
void Command (int reg_addr, int data_addr)
	ins_reg(reg_addr);
	data_reg(data_addr);
void LCD_STROBE ()
	 LCD_EN = 0;
	 DelayMs(1);
	 LCD_EN = 1;
const unsigned char Text_Screen[16][41]=
  {"01234567890123456789012345678901 00 6789",  // 00
   "012345678                    901 01 6789",  // 01
   "012345678 40 col by 16 lines 901 02 6789",  // 02
   "012345678    of 5x7 text     901 03 6789",  // 03
   "012345678   built-in font    901 04 6789",  // 04
   "012345678                    901 05 6789",  // 05
   "01234567890123456789012345678901 06 6789",  // 06
   "01234567890123456789012345678901 07 6789",  // 07
   "01234567890               678901 08 6789",  // 08
   "01234567890 ABCDEFGHIJKLM 678901 09 6789",  // 09
   "01234567890 NOPQRSTUVWXYZ 678901 10 6789",  // 10
   "01234567890 abcdefghijklm 678901 11 6789",  // 11
   "01234567890 nopqrstuvwxyz 678901 12 6789",  // 12
   "01234567890               678901 13 6789",  // 13
   "01234567890123456789012345678901 14 6789",  // 14
   "01234567890123456789012345678901 15 6789"}; // 15
main()
	DelayMs(250);
	TRISA = 0;TRISB = 0; //Port A & B Set as OutPut
	LCD_CS = 1; //Chip Disable
	LCD_EN = 1;
	LCD_RS = 1;
	PORTB = 0b00000000; //DB0 - DB7 all at low level
	DelayMs(250);
                // START INIT ***
	Command(0,60);     //Mode Control       00111100
	Command(1,117);   //Character Pitch    01110101
	Command(2,39);     //Number of Char.
                Command(10,0);     //Cursor low address setting
	Command(11,0);     //Cursor hiigh address setting
//Send data command
PORTB = 0b00001100;  //write code "0CH"
LCD_RS = 1;
DelayMs(20);
LCD_STROBE();
LCD_RS = 0;
DelayMs(20);
  for(row=0;row<=15;row++)
    for(col=0;col<=39;col++)
      PORTB = Text_Screen[row][col];
      DelayMs(20);
      LCD_STROBE();
LCD_CS = 1;
while(100);
:confused:
