CrystalControl2 has extensive logging support to help with debugging problems.
To make it easier for us to help you with a problem, it is suggested you do the following:
If you think other information will help (like screenshots, etc), please attach them in the thread also.
We will try to have an answer for you as soon as possible.
- Stop CrystalControl2 using the Windows Startbar control
- Browse to the directory where CrystalControl2 configuration files are stored ("C:\program files\CrystalControl2" in WinXP, "C:\ProgramData\CrystalControl2" in Vista/Win7)
- Delete all the existing log files (Files with the ".log" extension)
- Open the file "logprefs.ini" in a text editor like notepad, and change the "file_level" setting to a value of "0". Save the file and close the text editor
- Start CrystalControl2, and let it run until the problem occurs, and for a few minutes after.
- Using an archive program like WinZip, compress all the ".log" files and ".ini" files in the CrystalControl2 directory into a zip file
- Start a new thread in this forum reporting your problem in detail, and attach the zip file you created
