How can i connect my CFAH2004A-TMI-JP to pc?
mAs
I would like to know how connect my new display to pc.
Tnx
Gabriele
PS: Excuse my english, but i'm italian and speak english so so.
We do not offer end-user tech support on the CFAH* series LCDs in PC applications. We will not accept returns on CFAH* LCDs damaged in an attempt to connect them to a PC.
That said, good wiring guides for HD44780 compatible LCD's can be found:
http://www.myrolypoly.com/lcd_project/lcd_project.html
http://www.icehw.net/article.asp?id=104
http://www.geocities.com/ResearchTriangle/1495/ee_lcd.html
http://www.hardforum.com/showthread.php?threadid=248302
You can also go to http://forums.bit-tech.net/showthread.php?threadid=5582 and search for "assuming alphanumeric" and you will find a short Q/A post on parallel displays.
Character LCD Modules
