A couple days ago, I installed Vista. I knew going in that there would be problems with Vista and CC2. So... If you must have Vista and you are using CC2 (why else would you be here?
), here is what I have done.
1. While I still had XP installed, I added/deleted any screens that I wanted in Vista. In my case, I removed most screens that required external apps, such as ATI Tray Tools, Speedfan, etc. Also (very important), remove any screens that use Everest data. CC2 has a serious memory leak when using Everest data.
Also, (very important!) if you have your display set to dim, when idle, disable it.
2. Save all the ini files to a save place.
3. Install Vista. Install drivers/programs as you desire.
4. Install the CF USB drivers. Using the Device Manager, install your display(s).
5. Install CC2. Latest version, of course!
So far, just like XP.
6. Now, copy back your SAVED ini files into the CC2 directory.
7. Either restart your computer or start the CC2_service using Windows Services.
8. Your displays should now be working, just like in XP.
Why this method? The CC2 config program can not access the CC2_service program. I did remove 1 screen using the config program. So you actually may be able to add/delete screens using the config program, you simply cannot use it to start CC2.
Also, I don't remember if the service was running when I deleted a screen. It's just best to stop the service, if you need to add/remove screens. It may also be possible to change the dimming option this way also.
Please note that this is for 32-bit Vista. I had absolutely no luck getting the displays to install using 64-bit Vista.
And FWIW, the service has died a couple times over the past view days. Mostly when adding programs or changing some other configuration. Been working fine, otherwise.
Questions?
JC
Questions?
JC
