i'm using a modified test635 C source to program temperature and fanspeed reporting. I run this command in a loop every 500ms to read out the values:
The program is running under linux and if I set fan 1 to 84% and enable fanspeed report I recieve this from the function ShowReceivedPacket()
C=129( 1 = Read Version),L=4,D="\000\011\172N",CRC=0xB7FF5F95
The values after D="\000\ vary and I can not find any logic. The first three 000 tell me which fan is reported but the rest looks very confusing to me.
The same when I use temperature reporting, I use the same function as above and I'll get this:
C=130( 2 = Write Flash),L=4,D="\000v\001\001",CRC=0xB7FB893B
Can someone tell me what I have to change in that function, so that I get "real" values?!
Note:
I think it is because the incoming data is being formated to a string. If I look at it with a packet sniffer the structure of the packets look like it is described in the manual.
int timed_out = 1;
for(int k=0;k<=10000;k++)
if(check_for_packet())
ShowReceivedPacket();
break;
if(timed_out)
Note:
