Does Crystalfontz support LCDcenter?
TechGuyOne
Hi, do the Crystalfontz range of products support the software "LCDcenter" and if so, which setting would it be on.
1. lcdriver
2. Matrix orbital
3. HD44780
This is really a question you should ask the author of LCDcenter. That being said, I think that the serial dispalys (632 and 634) would be set to "LCDriver" and any of the parallel displays (CFAH* series) would be set to "HD44780".
TechGuyOne
Thank you for your prompt reply, yes after a bit of searching I found out that you are quite right. it's lcd for the monitor I'm getting :)
