DIABLO16 Module
Jordan1x
Hi everyone,
I’m working on a little display project and I found this module, DIABLO16 intelligent display module , that looks like it could simplify things a lot. Instead of using a basic character LCD + controller + wiring all signals manually, this module comes with a built-in graphics processor, its own drive electronics, and serial/I²C interface, in theory, it makes display control much simpler.
What I’m imagining: I could connect DIABLO16 to a microcontroller (or single-board system), send simple commands or data over serial, and let the module handle drawing text, graphics or menu screens. That seems easier than bit-banging a character LCD, and gives me more flexibility (fonts, layout, maybe even images).
Before I start, I wanted to ask those of you with experience:
  • Has anyone here used DIABLO16 (or similar “smart display” modules) instead of a standard character LCD? How did it work out, was it more reliable or did it cause new problems (e.g. overhead, lag, weird quirks)?
  • When wiring these modules: any tips on power supply decoupling, contrast/brightness control, or grounding to avoid display artifacts?
  • For menu-based or dynamic displays: is the serial-command overhead noticeable (sluggish)? Is it convenient enough for small projects, or overkill compared to simple character LCDs?
  • If you tried driving DIABLO16 from microcontrollers that usually drive character LCDs: how do you like the tradeoff, more power and flexibility vs. simplicity and lower cost?
I’m leaning toward trying the DIABLO16 for a more flexible, feature-rich display, but I’d love to hear your real-world experiences before investing time & money.
Thanks in advance!
CF Kelsey
We don't have experience with DIABLO16, however we do have a line of display modules that might be interesting to you. They are built using Bridgetek's EVE IC line.
Our EVE accelerated displays allow you to use a low-powered/slow processor (like Arduino) and still be able to write quickly to larger TFT displays.
EVE Features:
  • Built-In Touch Control – Capacitive, resistive, or no touch, over the single SPI interface
  • Faster Communication – MCU interfacing via SPI, Dual SPI or Quad SPI options
  • Built-In Audio – Mono 8-bit linear audio wave PWM playback
  • EVE Screen Designer – GUI drag and drop design suite
  • All the Colors! – Multiple 16/32 bit color palettes supported with transparency & 24-bit depth
  • Super Smooth Playback – JPG encoded AVI video playback
  • Huge Memory! – 1 Mega-byte of object memory no frame buffer needed on your MCU
  • Widgets – Hardware support for multiple buttons, sliders, gauges, including touch detection.
  • Orientation – Landscape, Portrait you got it! (*with compatible IPS Display)
  • Hot and Cool! – Extended Operating temperature range: -20C to 70C
  • Fast Development – High level API, provided by Bridgetek, to help you create your project quickly.
