Here is a quick tutorial showing how to connect a Crystalfontz CFAL5016A-Y 50x16 Graphic OLED Module in SPI mode to an Arduino Uno R3.
Connect some WRJMPY40 or similar wires to the Arduino as shown here:
The other ends push onto the OLD module's header like so:
Load up the Arduino Sketch (Arduino_SPI_OLED_Example_Code.ino):
The OLED should power up and you should have the it cycling through a couple of screens:
Here is a video of the demonstration in action:
Happy hacking! Be sure to contact us if you have any questions or troubles getting your display going.
![](http://baxsie.com/images/forum/Arduino_Graphic_SPI_OLED_CFAL5016A-Y/Arduino_With_Graphic_OLED_SPI_Connections_Arduino.jpg)
![](http://baxsie.com/images/forum/Arduino_Graphic_SPI_OLED_CFAL5016A-Y/Arduino_With_Graphic_OLED_SPI_Connections_OLED.jpg)
// Code written for Arduino Uno
// CRYSTALFONTZ CFAL5016A-Y 50x15 Graphic OLED IN SPI MODE
// ref: https://www.crystalfontz.com/product/cfal5016ay
// video: https://www.youtube.com/watch?v=By0t1mrXsO8
// tutorial: https://forum.crystalfontz.com/showthread.php/7395
// 2016 - 01 - 22 Brent A. Crosby
//This is free and unencumbered software released into the public domain.
//Anyone is free to copy, modify, publish, use, compile, sell, or
//distribute this software, either in source code form or as a compiled
//binary, for any purpose, commercial or non-commercial, and by any
//means.
//In jurisdictions that recognize copyright laws, the author or authors
//of this software dedicate any and all copyright interest in the
//software to the public domain. We make this dedication for the benefit
//of the public at large and to the detriment of our heirs and
//successors. We intend this dedication to be an overt act of
//relinquishment in perpetuity of all present and future rights to this
//software under copyright law.
//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
//EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
//MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
//IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR
//OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
//ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
//OTHER DEALINGS IN THE SOFTWARE.
//For more information, please refer to <http://unlicense.org/>
//Software SPI (10-bit transfers, difficult to do using the hardware SPI)
#define SPIPORT (PORTB)
#define SPITOGGLE (PINB)
// PB5 (0x20) is SCK (output) green OLED pin 12
#define SPI_SCK_PIN (13)
#define SCK_MASK (0x20)
#define CLR_SCK (PORTB &= ~(SCK_MASK))
#define SET_SCK (PORTB |= (SCK_MASK))
// PB4 (0x10) is MISO (input) blue OLED pin 13
//(reference only, it is an input)
#define SPI_MISO_PIN (12)
#define MISO_MASK (0x10)
#define CLR_MISO (PORTB &= ~(MISO_MASK))
#define SET_MISO (PORTB |= (MISO_MASK))
// PB3 (0x08) is MOSI (output) violet OLED pin 14
#define SPI_MOSI_PIN (11)
#define MOSI_MASK (0x08)
#define CLR_MOSI (PORTB &= ~(MOSI_MASK))
#define SET_MOSI (PORTB |= (MOSI_MASK))
// DB2 (0x04) is SS (output) gray OLED pin 15
#define SPI_SS_PIN (10)
#define SS_MASK (0x04)
#define CLR_SS (PORTB &= ~(SS_MASK))
#define SET_SS (PORTB |= (SS_MASK))
#define DATA (1)
#define COMMAND (0)
// Graphic data to display on LCD.
// Image2Code may be helpful to create your own screen image:
// https://forum.crystalfontz.com/showthread.php/5854
// http://sourceforge.net/p/image2code/code/HEAD/tree/
const char LOGO_Screen[2][50] PROGMEM =
{0xF0,0xF0,0xF4,0xF6,0xF3,0xF1,0xF3,0x02,0xF8,0xFC,0xFE,0x03,0x51,0x53,
0x56,0x54,0x50,0x50,0x50,0x00,0x00,0xF0,0xFC,0x1E,0x0F,0x07,0x07,0x07,
0x0F,0x1E,0x08,0x00,0xFF,0xFF,0xC7,0xC7,0xC7,0xC7,0xC7,0x07,0x00,0x80,
0xF8,0x7F,0x07,0x7F,0xF8,0x80,0x00,0x00},
{0x07,0x07,0x17,0x37,0x67,0x47,0x67,0x20,0x0F,0x1F,0x3F,0x60,0x45,0x65,
0x35,0x15,0x05,0x05,0x05,0x00,0x00,0x0F,0x3F,0x78,0xF0,0xE0,0xE0,0xE0,
0xF0,0x78,0x10,0x00,0xFF,0xFF,0x01,0x01,0x01,0x01,0x01,0xC0,0xFC,0x3F,
0x0F,0x0E,0x0E,0x0E,0x0F,0x3F,0xFC,0xC0}
const char OLED_Screen[2][50] PROGMEM =
{0xE0,0xF8,0xFC,0x0E,0x03,0x01,0x01,0x01,0x03,0x0E,0xFC,0xF8,0xE0,0x01,
0x01,0xFF,0xFF,0xFF,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0xFF,
0xFF,0xFF,0x81,0xC1,0xF9,0x03,0x07,0x1F,0x00,0x01,0x01,0xFF,0xFF,0xFF,
0x01,0x01,0x01,0x03,0x0E,0xFC,0xF8,0xE0},
{0x07,0x1F,0x3F,0x70,0xC0,0x80,0x80,0x80,0xC0,0x70,0x3F,0x1F,0x07,0x80,
0x80,0xFF,0xFF,0xFF,0x80,0x80,0x80,0x80,0xC0,0xF0,0x1C,0x80,0x80,0xFF,
0xFF,0xFF,0x80,0x81,0x8F,0x80,0xC0,0xC0,0x78,0x80,0x80,0xFF,0xFF,0xFF,
0x80,0x80,0x80,0xC0,0x70,0x3F,0x1F,0x07}
const char TEXT_Screen[2][50] PROGMEM =
{0x00,0x0E,0x11,0x11,0x00,0x9F,0x85,0x9A,0x80,0x83,0x9C,0x03,0x00,0x16,
0x95,0x8D,0x80,0x81,0x9F,0x01,0x00,0x1E,0x05,0x1E,0x00,0x1F,0x10,0x10,
0x00,0x1F,0x05,0x01,0x80,0x0E,0x11,0x0E,0x00,0x1F,0x02,0x9F,0x80,0x81,
0x1F,0x01,0x00,0x19,0x15,0x13,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x4F,0xCF,0x88,0x88,0xF8,0x70,0x00,0x00,0x7F,
0xFF,0xB0,0x9C,0x86,0xFF,0x7F,0x00,0x84,0xCC,0x78,0x30,0x78,0xCC,0x84,
0x00,0x82,0x82,0xFF,0xFF,0x80,0x80,0x00,0x00,0x7E,0xFF,0x89,0x88,0xF8,
0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00}
const char CHECK_Screen[2][50] PROGMEM =
{0xAA,0x55,0xAA,0x55,0xAA,0x55,0xAA,0x55,0xAA,0x55,0xAA,0x55,0xAA,0x55,
0xAA,0x55,0xAA,0x55,0xAA,0x55,0xAA,0x55},
const char VLINES_Screen[2][50] PROGMEM =
{0xFF,0x00,0xFF,0x00,0xFF,0x00,0xFF,0x00,0xFF,0x00,0xFF,0x00,0xFF,0x00,
0xFF,0x00,0xFF,0x00,0xFF,0x00,0xFF,0x00},
const char HLINES_Screen[2][50] PROGMEM =
{0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,
0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA},
void write_to_OLED_SPI(uint8_t destination,uint8_t data)
//Bits sent in this order:
// data(1)/command(0) flag
// read(1)/write(0) flag
// data.7 (msb)
// data.6
// data.5
// data.4
// data.3
// data.2
// data.1
// data.0 (lsb)
#if(1)
//Pretty fast software SPI 10-bit transfer code
//Several ideas taken from the fastest non-assembly implementation at:
//http://nerdralph.blogspot.com/2015/03/fastest-avr-software-spi-in-west.html
// The SS pin is low for ~3.8uS, the clock frequency is ~ 2.6MHz
// 47x faster than above
//Pre-calculate the value that will drive clk and data low in one cycle.
//(Note that this is not interrupt safe if an ISR is writing to the same port)
register uint8_t
force_clk_and_data_low;
//Select the chip
CLR_SS;
//operation.
force_clk_and_data_low = (SPIPORT & ~(MOSI_MASK | SCK_MASK) );
//Set clock and data low
SPIPORT = force_clk_and_data_low;
//Set the data(1)/command(0) flag
if(DATA==destination)
SPITOGGLE = MOSI_MASK;
//Use a toggle to bring the clock up
SPITOGGLE = SCK_MASK;
//MOSI is already 0, for read(1)/write(0) flag as write
//Now clock the 8 bits of data out
if(data & 0x80)
if(data & 0x40)
if(data & 0x20)
if(data & 0x10)
if(data & 0x08)
if(data & 0x04)
if(data & 0x02)
if(data & 0x01)
//Release the chip
SET_SS;
#else
//Straight-forward software SPI 10-bit transfer code, perhaps
//easier to understand, possibly more portable. Certainly slower.
// The SS pin is low for ~180uS, the clock frequency is ~57KHz
// 47x slower than above
//Select the chip, starting a 10-bit SPI transfer
digitalWrite(SPI_SS_PIN, LOW);
//(bit 0) Set the data(1)/command(0) flag
digitalWrite(SPI_MOSI_PIN, HIGH);
else
digitalWrite(SPI_MOSI_PIN, LOW);
//Clock it in.
digitalWrite(SPI_SCK_PIN, LOW);
digitalWrite(SPI_SCK_PIN, HIGH);
//(bit 1) Clear the read(1)/write(0) flag to write, clock it in.
//Clock it in.
//(bits 2-9) Push each of the 8 data bits out.
for(uint8_t mask=0x80;mask;mask>>=1)
//Set the MOSI pin high or low depending on if our mask
//corresponds to a 1 or 0 in the data.
if(mask&data)
else
//Clock it in.
//Release the chip, ending the 10-bit SPI transfer
digitalWrite(SPI_SS_PIN, HIGH);
#endif
//#define WriteCommand(command) write_to_OLED_SPI(COMMAND, command)
//#define WriteData(data) write_to_OLED_SPI(DATA, data)
void position_cursor(uint8_t column, uint8_t line)
//Set CGRAM Address, RS=0,R/W=0
// 7654 3210
// 1AAA AAAA
// 0x00 to 0x27 => Line 1
// 0x40 to 0x67 => Line 2
write_to_OLED_SPI(COMMAND,0x80 | (column&0x7F));
//Line / Y/8
write_to_OLED_SPI(COMMAND,0x40 | (line&0x01));
// According to the WS0010 data sheet, only the clear display time has
// an appreciable execution time of 6mS. All others are listed at 0.
void clear_display(void)
//Display Clear RS=0,R/W=0
// 7654 3210
// 0000 0001
write_to_OLED_SPI(COMMAND,0x01);
_delay_ms(6);
void initialize_display()
//Refer to WS0010 data sheet, page 21
// https://www.crystalfontz.com/products/document/3176/WS0010.pdf
//The display controller requests:
// "Wait for power stabilization 500ms:
_delay_ms(500);
//Function set, RS=0,R/W=0
// 7654 3210
// 0011 NFFT
// N = lines: N=1 is 2 lines
// F = Font: 0 = 5x8, 1 = 5x10
// FT = Font Table:
// FT=00 is English/Japanese ~"standard" for character LCDs
// FT=01 is Western European I fractions, circle-c some arrows
// FT=10 is English/Russian
// FT=11 is Western European II my favorite, arrows, Greek letters
write_to_OLED_SPI(COMMAND,0x3B);
//Graphic vs character mode setting, RS=0,R/W=0
// 7654 3210
// 0001 GP11
// G = Mode: 1=graphic, 0=character
// C = Power: 1=0n, 0=off
write_to_OLED_SPI(COMMAND,0x1F);
//Display On/Off Control RS=0,R/W=0
// 7654 3210
// 0000 1DCB
// D = Display On
// C = Cursor On
// B = Cursor Blink
write_to_OLED_SPI(COMMAND,0x0E);
// 7654 3210
// 0000 0001
clear_display();
//Display home
write_to_OLED_SPI(COMMAND,0x02);
//Entry Mode Set RS=0,R/W=0
// 7654 3210
// 0000 01IS
// I = Increment/or decrement
// S = Shift(scroll) data on line
write_to_OLED_SPI(COMMAND,0x06);
// 7654 3210
// 0000 0001
clear_display();
// ref: http://stackoverflow.com/questions/28787177/c-arduino-passing-pointer-to-2d-array-stored-in-progmem-to-a-function
void Send_Logo(const char (&screen)[2][50],uint8_t invert)
uint8_t
i;
uint8_t
j;
position_cursor(0,0);
//Logo
//Send the image from the flash to the LCD.
//This "normal" version takes about 3.1mS to fill the screen from the image in
//flash, using 8MHz SPI transfers.
for(j=0;j<=1;j++)
// Point the controller to the correct address. This is the Y coordinate,
// addressed by 8 pixel / 1 byte horizontal bands.
position_cursor(0,j);
//Dump the data out for this line.
if(invert)
for(i=0;i<=49;i++)
write_to_OLED_SPI(DATA,~pgm_read_byte(&screen[j][i]));
else
for(i=0;i<=49;i++)
write_to_OLED_SPI(DATA,pgm_read_byte(&screen[j][i]));
void setup()
//General setup, port directions.
pinMode(SPI_SCK_PIN, OUTPUT);
pinMode(SPI_MISO_PIN, INPUT);
pinMode(SPI_MOSI_PIN, OUTPUT);
// DB2 (0x04) is SS (output) gray OLED pin 16
pinMode(SPI_SS_PIN, OUTPUT);
void loop()
//Simple demo loop
// Initialize the display
initialize_display();
_delay_ms(200);
Send_Logo(TEXT_Screen,0);
_delay_ms(1000);
Send_Logo(LOGO_Screen,0);
_delay_ms(1000);
Send_Logo(OLED_Screen,0);
_delay_ms(1000);
Send_Logo(CHECK_Screen,0);
_delay_ms(1000);
Send_Logo(CHECK_Screen,1);
_delay_ms(1000);
Send_Logo(VLINES_Screen,0);
_delay_ms(1000);
Send_Logo(VLINES_Screen,1);
_delay_ms(1000);
Send_Logo(HLINES_Screen,0);
_delay_ms(1000);
Send_Logo(HLINES_Screen,1);
_delay_ms(1000);
![](http://baxsie.com/images/forum/Arduino_Graphic_SPI_OLED_CFAL5016A-Y/Arduino_With_SPI_Graphic_OLED_Overall.jpg)
