I'm writing my own software for interfacing with with the CFAH0802A-YYB-JP LCD.
I was looking over a tutorial that was setting PIN 17 as high (to indicate command is coming).
For my LCD would I have to set PIN 16 to high to show that the command is coming?
Seems to be that CFAH0802A-YYB-JP uses PIN16 (INT) like the tutorial i'm reading is using PIN 17 (SELECT INPUT).
I'm using this code as an example:
http://www.beyondlogic.org/parlcd/parlcd.htm
