CrystalControl2 - 20060216
Status
Not open for further replies.
CrystalControl2 - 16/02/2006
It is recommended that you uninstall older versions of CrystalControl2 before installing this new version!
Not doing so will cause problems.
HD44780 support has been reintroduced in this version of CrystalControl2.
Version History:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
See below for updates for this release
(none as yet)
Status
