CrystalControl2 - 24/07/2005
Service Version: V1.00
Configure Version: V1.00
It is recommended that you uninstall older versions of CrystalControl2 before installing this new version!
Not doing so will cause problems.
HD44780 support have been removed from this release of CrystalControl2 due to problems with the IO port driver.
Support will be re-introduced when this problem has been fixed.
Version History:
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
See below for updates for this release
(none as yet)
Version History:
- New screens
- Manual updates
(none as yet)
