CrystalControl2 - 17/12/2004 (get it here)
Status
Not open for further replies.
Service Version: V1.00
Configure Version: V1.00
Version History:
- First public release
See below for updates
Attached to this post is the new screens that support FRAPS version 2.5.0.
Extract the contents of the ZIP file into your "cc2-config\screens\Fraps" directory.
  • fraps-250-screens.zip
Attached is the two DLLs that are required by CrystalControl2 that are not included with Windows.
If you have problems with CrystalControl2 or some of the plugins loading, extract the contents of the ZIP file to your "c:\windows\system32" directory.
If the files already exist, do not overwrite them.
  • cc2-dlls.zip
Attached is the updated cc2_process.dll plugin file.
It fixes problems with FRAPS FPS readings among other things.
Download and copy the file into your "cc2-service" directory overwriting the old one.
You will need to stop CrystalControl2 first.
  • cc2_process.dll
Attached is updated LCD plugin dll files for all supported module types.
Updates:
631/633 - New com port settings, different default stats log file names.
632/634 - New com port settings, fixes serial LCD display problems.
HD44780/HD44780d - Now logs on CANIO init failiures.
It is recommended everyone update to these new plugins.
To install, stop CrystalControl2 and extract the contents of this ZIP file into the "cc2-service" directory overwriting the existing files.
  • updated-lcd-plugins.zip
Attached is an updated games plugin which supports Halflife and CounterStrike Source.
Stop CrystalControl2 then copy the file into your "cc2-service" directory overwriting the older version.
  • cc2_games.dll
Status
