CrystalControl2 - 16/02/2006 - HD44780 still not working.
undrsc0re
Previously uninstalled CC1/CC2. Installed the above release. Rebooted and CC2 ran fine. Configured it with no errors, HD4470, 20x4, 0x378, mobo port set to EPP. Loaded a sample screen and nothing comes up on the screen.
I know the screen works because I have tested it with CFAH_Wintest and also LCDSmartie.
Please help. Thanx.
  • crystalcontrol2.zip
Ok, can you kill the cc2_service in task manager, then copy these new attached files in (overwrite the old ones), then restart CC2.
Itll generate better logging so i can work out exactly what the problem is.
Ill only need the "cc2_service.log" and "lcd_hd44780.log" files.
  • hd44780-test1.zip
Thanks for those.
That gives me an idea as to whats causing the problem.
Hopefully ill have a fix soon.
