CrystalControl2 - 12/08/2007
Status
Not open for further replies.
Release notes for Vista users:
- The CrystalControl2 configuration application will not be able to access some PC statistics due to the Vista security measures. This can be bypassed by running the CC2 config app as Administrator. To have it always run as administrator, see this information.
- Your old settings will not be found on running the this version of CC2 as the files are now stored in a different location ("C:\ProgramData\CrystalControl2"). To use your old settings, copy your old INI files to this new location.
- Quite a few applications that use shared-memory to share information will no longer work due to Vista's security measures. Nothing can be done about this.
- Dim LCDs on idle is not supported under Vista (once again, due to Vista security).
- If you are using Winamp2 or Foobar2000, make sure you install the new plugins.
Release notes for XP users:
- None, everything works as normal.
Version History:
12/08/2007:
- New Rivatuner plugins
- Fixed E01's in email plugin
20/07/2007:
- Tweaked timing routines.
- Many more small fixes.
25/12/2006:
- New Screen-Editor!
- Screen transition effects!
- New plugins.
- Lots of bug fixes.
25/03/2006:
- Fixed empty string INI bug.
- New kill_cc2 utility.
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
Status
