CrystalControl2 - 03/04/2008
Note: This release of CrystalControl2 has had very limited amounts of beta testing, and it is quite likely a few bugs exist. If you have problems, please report them in the forum.
Version History:
03/04/2008:
- New rFactor plugin
12/08/2007:
- New Rivatuner plugins
- Fixed E01's in email plugin
20/07/2007:
- Tweaked timing routines.
- Many more small fixes.
25/12/2006:
- New Screen-Editor!
- Screen transition effects!
- New plugins.
- Lots of bug fixes.
25/03/2006:
- Fixed empty string INI bug.
- New kill_cc2 utility.
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
Version History:
03/04/2008:
12/08/2007:
20/07/2007:
25/12/2006:
- New plugins.
25/03/2006:
26/02/2006:
16/02/2006:
- New screens
- New screens
- Manual updates
