Controlling backlight
Mur
To amuse myself, I'm trying to learn how to control the 20x4 crystalfontz lcd myself. At the moment I'm using Perl, as it's a quick language. Anyway, I can't for the life of me figure out how to control the backlight... Sample program:
#!/usr/bin/perl
use FileHandle;
open (LCD, ">/dev/ttyS0");
LCD->autoflush();
sleep(3);
print LCD "Hello World";
print LCD "\014\020"; # back light to 20% .. from .pdf
sleep(6);
close (LCD);
exit 0;
Obviously, the syntax that I'm using must not be correct. Does anyone have any suggestions?
The "\xxx' (where xxx = 000 to 255) is just a notation used in WinTest and the data sheet for a "binary" number.
So "\013" is a single byte with a value of:
13 decimal
0x0D hex
"CR" ASCII
So the trick will be figuring out how to talk Perl into sending an arbitrary value byte out the serial port, then use that sequence every time you see the \xxx.
