Connect between 8052 with COG-LCD S6B1713
duongimi
I'm studying about S6B1713. However, I can't initialize and show data on this LCD.
If you have experience in this problem, please help me.
Regards.
Duongimi
duongimi
Diagram of S6B1713
I determine the order of pins of S6B1713 (29 pins) as attached pictures follow;
If any problem, please reply to me.
Regards !
Duong
duongimi
Diagram for S6b1713(29 pins)
I have some troubles with S6b1713(29 pins). Anyone knows about diagram and schematic of this LCD, please send me. Thank you very much !
duongimi
Problems with Initialize and Display S6b1713(KS0713)
I use a microprocessor connect with COG-LCD S6b1713(29pins).
My program as follow:
;Define Bit and Mode
#define LCD_RSBL  Port1_7(0)
#define LCD_RSBH  Port1_7(1)
#define CLR_WR    Port1_5(0)
#define SET_WR    Port1_5(1)
#define CLR_RS    Port1_6(0)
#define SET_RS    Port1_6(1)
#define SET_E	  Port1_4(1)
#define CLR_E     Port1_4(0)
#define SET_P13   Port1_3(1)
#define CLR_P13   Port1_3(0)
#define PORTD     PRT0DR
#define LCD_CMD_ADC	      0xA1//Select SEG output direction(Normal)
#define LCD_CMD_ON	      0xAF//Display On
#define LCD_CMD_EON       0xA5//Entire display(Entire ON)
#define	LCD_CMD_REVERSE   0xA6//Reverse display ON/OFF(Normal)
#define LCD_CMD_BIAS	  0xA3//Select LCD Bias
#define LCD_CMD_SHL		  0xC0//Select COM output direction(Normal)
#define LCD_CMD_POWERC	  0x2F //Power
#define LCD_CMD_RES		  0x26 // Regulator resistor
#define LCD_CMD_SIM		  0xAD//Set static indicator mode
#define LCD_CMD_SIR       0x03//Set static indicator Register(ON)
#define LCD_CMD_IDL		  0x40//Set Line Address(Line0)
#define LCD_CMD_SVM		  0x81//Set Reference voltage mode
#define LCD_CMD_SRV		  0x3F//Set Reference voltage register
#define LCD_CMD_RESET	  0xE2//Initialize the internal functions
#define LCD_CMD_CLMSB     0x10//Set Colum MSB(Colum0)
#define LCD_CMD_CLSB      0x00//Set Colum LSB
#define LCD_CMD_MR        0xE0//Set Modify-read Mode
#define LCD_CMD_RMD		  0xEE//Release Modify-read mode
; Init
void Init(void){
	BYTE index;
	BYTE i;
	PORTD = LCD_CMD_RESET;//
	CLR_WR;
	SET_WR;
	Trems();
    PORTD =LCD_CMD_ON; //turn display on
	CLR_WR;
	SET_WR;
	Trems();
	PORTD = LCD_CMD_EON;
	CLR_WR;
	SET_WR;
	Delay50uTimes(20);
	PORTD = LCD_CMD_REVERSE;
	CLR_WR;
	SET_WR;
	Delay50uTimes(20);
	PORTD = LCD_CMD_BIAS;
	CLR_WR;
	SET_WR;
	Delay50uTimes(20);
	PORTD = LCD_CMD_ADC;  //adc
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = LCD_CMD_SHL;
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = 0x2A;
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = 0x29;
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = LCD_CMD_POWERC;//Voltage Converter ON,Voltage Regular ON,Voltage Follower ON
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = LCD_CMD_RES;//Regulator resistor select
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = LCD_CMD_SVM;//Set reference voltage
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = LCD_CMD_SRV;
	CLR_WR;
	SET_WR;
	Delay50uTimes(200);
	PORTD = LCD_CMD_SIM;//Set static indicator
	CLR_WR;
	SET_WR;
	Trems();
	PORTD = LCD_CMD_SIR;//Set static indicator
	CLR_WR;
	SET_WR;
	Delay50uTimes(20);
void LCD_logo(void){
  BYTE row;
  BYTE  col;
  BYTE i;
  for(row=0;row<=7;row++)
    //Page Address
    PORTD = 0xB0|row;
    CLR_WR;
	SET_WR;
    Delay50uTimes(200);
    //High Column
    PORTD = 0x10;
    CLR_WR;
	SET_WR;
    Delay50uTimes(200);
	PORTD = 0x00;
	CLR_WR;
	SET_WR;
    Delay50uTimes(200);
    SET_RS;
    for(col=0; col<132; col++)
		PORTD = cfax12864a[row][col];//Get from CFAG12864B_WinTest:D
		CLR_WR;
		SET_WR;
		CLR_WR;
		SET_WR;
		for(i = 0; i<10; i++)
			Trems();
    CLR_RS;
void External_Setup(void){
	BYTE i;
	SET_WR;
	CLR_RS;
	LCD_RSBL;                //ResetB low
	for(i = 0; i< 10; i++);
		Trems();//Delay 1ms
	LCD_RSBH;
		Trems();
; Main
void main()
	BYTE i,j,line=0;
	External_Setup();
	Init();
	while(1){
		LCD_logo();
However, On the screen it is only continuous flicker. I don't know why ?
Anyone can help me !
Regards!
Duong
