I am am designing a PCB that will interface a CFAL160128B display to a PIC24...I want to run the pic and associated auxially circuits with +3.3V supply.
I'd like to confirm the supply voltages for the display:
From the CFAL160128B preliminary data sheet
VDD (Supply Voltage for Logic pin 27) min 2.2V typ 2.8V max 2.9V
IOVDD (???) min 2.2V , max 3.3V
Q1: Can I just use a LL4148 diode to drop my +3.3V supply to within spec (approx. 2.8V) for the OLED VDD?
Q2: Can i drive the display bus and control (db0,db1...wr, cs etc) lines directly from my PIC24 (at 3.3V)
Q3: What is IOVDD? (I think it the acceptable range of IO drive voltages refered to in Q2 but i'd like confirmation.)
If this is a problem/likely problem with my approach I can choose vdd=2.8V for my PIC24 and make voltage adjustments else where as needed...but I'd rather not do this.
Many thanks and cheers,
Neal
Neal
